Managing Safari Bookmarks?
  • April 19, 2010
  • 19 replies
  • 174 views
I hope I'm not missing something totally obvious, but I can't find where to set up pre-configured Safari bookmarks. We deploy (with our current monolithic image) a standard set of Safari bookmarks for users, and I would like to migrate that customization into Casper without having to bake it into my OS image.
Has anyone else done this with success?
Thanks,
Pete
  • April 19, 2010
Well, like I said, I knew it would be kind of obvious, but I appreciate all the help.
Now my issue is that I can push the DMG with the bookmarks via Remote, but it doesn't seem to go during imaging...
Any thoughts?
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • April 19, 2010
Sounds like you haven't selected "Fill User Template" or "FUT" for the
On 4/19/10 2:18 PM, "Wann, Peter" <p.wann at tcu.edu> wrote:
package. Set this in the JSS or via Casper Admin. All new logins should
receive the bookmarks.
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
  • April 19, 2010
Here is what I do and is a little more involved than other methods.
Modify a copy of /Applications/Safari.app/Contents/Resources/English.lproj/BuiltInBookmarks.plist
This is the plist file that creates the default bookmarks initially made for each user when they first launch the browser. Make your changes there and package it with Composer to replace the default file for Safari. This effectively injects your default bookmarks, replacing Apples. In my experience this will also keep throughout Safari updates. Use PlistEdit Pro or Apple's Property List Editor to make the initial changes (makes it easier to understand the layout). Since I like placing our internal bookmarks in the Bookmarks Bar - this works great for us, grouping them into the bookmarks bar folders.
Another file that may be of interest is /Applications/Safari.app/Contents/Resources/Defaults.plist - here is where you can set default settings like minimum fontsize, menu history limit, show statusbar, etc. I package my changes here as well into the same package with also a modified TopSites.plist and preference file to drop into the User Template directory for each new user account that is created on machine.
I have my package as part of my imaging workflow so every machine will get it before deployment and user account profile setup.
Michael Pebley
Discovery EUS
Macintosh Technical Lead and Desktop Engineer
I hope I'm not missing something totally obvious, but I can't find where to set up pre-configured Safari bookmarks. We deploy (with our current monolithic image) a standard set of Safari bookmarks for users, and I would like to migrate that customization into Casper without having to bake it into my OS image. Has anyone else done this with success? Thanks, Pete
Profiling fascinating true stories and featuring gripping interviews conducted by Emmy Award-winning journalist Paula Zahn, ON THE CASE WITH PAULA ZAHN is a shining example of Investigation Discovery’s mission to investigate life’s mysteries through riveting storytelling. ON THE CASE WITH PAULA ZAHN returns for its new season every Sunday night at 10 PM e/p on Investigation Discovery.
  • April 19, 2010
"Wann, Peter" <p.wann at tcu.edu> writes: I hope I'm not missing something totally obvious, but I can't find where to set up pre-configured Safari bookmarks. We deploy (with our current monolithic image) a standard set of Safari bookmarks for users, and I would like to migrate that customization into Casper without having to bake it into my OS image. Has anyone else done this with success?
I tried breifly but had no success with managing bookmarks easily. I changed my approach by imaging machines and setting the default page on the Configuration to our company portal page which contains all the links and bookmarks that our staff should be using.
Perhaps there's a way to set the default homepage remotely without reimaging?
Gene Anderson
Systems Analyst, ACTC, MCP
Pembina Hills Regional Division No.7
Phone: (780) 674-8535 ext 6860
email: ganderson at phrd.ab.ca
"I find your lack of faith disturbing..."
- Darth Vader, Sith Lord.
Forum|alt.badge.img+23
  • April 19, 2010
jamf help setHomePage
it has feu & fut options.
I hope this is helpful.
Miles Leacy
Technical Training Manager
Mobile (347) 277-7321
miles at jamfsoftware.com<mailto:miles at jamfsoftware.com>
JAMF Software
1011 Washington Ave. S
Suite 350
Minneapolis, MN 55415
Office: (612) 605-6625
Facsimile: (612) 332-9054
US Support: (612) 216-1296
UK Support +44.(0)20.3002.3907
AU Support +61.(0)2.8014.7469
http://www.jamfsoftware.com<http://www.jamfsoftware.com/>
  • April 19, 2010
As a follow up to Gene's post, here's a script using the JAMF binary to set
your default homepage for all browsers..
Run this via a policy or with Casper Remote;
/usr/sbin/jamf setHomePage -homepage 'http://www.google.com' -fut -feu
-- Jason Weber
Certified Casper Administrator
Technology Support Cluster Specialist
Independent School District 196
jason.weber at district196.org
  • April 19, 2010
Thanks everyone for the feedback, but I'm actually referring to setting and customizing the bookmarks, not just the home page. Setting the home page in the JSS configuration works great for me.
  • April 19, 2010
Have you tried packaging or writing to...
/Users/username/Library/Safari/Bookmarks.plist
Miles Leacy
JAMF Software
Suite 350
  • April 19, 2010
This works. I have done it for several years using various methods…currently
Dropbox. ;)
Ryan M. Manly
Glenbrook High Schools
? ACSP ? ACMT
Forum|alt.badge.img+31
  • April 20, 2010
Maybe this is just me, but this sounds like a job for Apple Script and Automator work flows.... Seeing as AS can directly interact with GUI apps, there is most likely a way to automate the import and export of a set book mark list via an Apple Script. I will admit that I don't know exactly how to code that myself off the top of my head.
-tom
  • April 20, 2010
Seeing how the user's bookmarks are just a plist, could it be handled with MCX settings with a custom template?
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
talkingmoose
  • Community Manager
  • April 20, 2010
The Safari bookmarks are in .plist format, but they're located in
On 4/20/10 8:31 AM, "Nichols, Jared - 1160 - MITLL" <jared.nichols at ll.mit.edu> wrote:
~/Library/Safari. All the research I've done to manage bookmarks has led me
to believe we can't manage these because of their location outside of
~/Library/Preferences.
If you know how to manage them via MCX, I'd really be grateful to learn how
you did it. I haven't been able to get this to work, even if I point to
~/Library/Safari.
William Smith
Technical Analyst
(651) 632-1492
  • April 20, 2010
I'm just positing here because I've never done it before, but could you
replace the ~/Library/Safari/bookmarks.plist file with a symlink to one
that MCX could actually handle?
--Jared F. Nichols
244 Wood Street
781.981.5436
bentoms
Forum|alt.badge.img+35
  • April 12, 2012
Anyone found a way of doing this with Casper MCX?
bentoms
  • May 19, 2014
  • May 20, 2014
The bookmarks file is not a preference, so it can’t be managed with preference management tools even though it is a plist.
The concern I have is not so much the initial population of the bookmarks, but maintaining it over time. Sites and systems bookmarked will probably change. Updating bookmarks seems to be a more difficult task overall — especially because you may not want to overwrite existing user bookmarks — and because of that, I personally think it’s better to find a different solution (like this) to the same need. Besides that, every browser handles this differently, so if you have another solution that can work across browsers, that would seem more ideal.
bentoms
  • May 20, 2014
Hi @jaharmi,
We use the Extension Bar to deploy links to company websites & resources. As it seems most web based products we have only support Safari on a Mac, we’ve found this is a good way to drive people to use Safari to access these sites, even if they use other browsers for general browsing.
With the linked sites being internally hosted, they rarely change.
  • May 20, 2014
@bentoms,
I’ve seen it both ways, internal sites that change and others that don’t (and even that probably depends upon the timescale). I think your idea of adding an extension is a reasonable alternative. It’s too bad that even that requires all this effort. Thanks for sharing your setup!
  • May 20, 2014
I agree with @jaharmi 's comments. Since we're working in a Casper Suite environment, Self Service URL plugins seems like a good solution to me. If you're interested in scoping different links to different computers/users, have a look at this article...
https://jamfnation.jamfsoftware.com/article.html?id=177
