Hi I am an Entry level support, fairly new to DEP. Today I manually added a machine to our DEP. I accepted the MDM profile and I believe everything is good. Now can someone tell me the next step in plain English? Isn't JAMF supposed to kick in and all our remote management will kick in? As you can tell I am not familiar with how this all works. There's someone above me who can help but wanted to find the solution first.
Steps I was told to do:
If machine is not on DEP(check the SN)
Go to > "Link for our jamfcloud enrollment"
Enroll the machine (downloads the profile)
Manually Install the MDM Profile.
Now this is the steps I am missing. I believe its done installing. What should I do next? Should I wipe the computer/restart/etc..
Machine: Big Sur 11.5.2
Thank you so much in advance 😄
