This is exactly what we have in our environment. Those settings that we managed using WGM does not get reset when deleting /Library/Managed Preferences/. We are having a hard time managing our end users.
Please let me know if you find any sort of command to temporarily resets managed preferences
Logging as root seems to bypass the managed preferences settings. However, there are times that needing to bypass managed pref under the end user accounts. I am really wanted to know if there is a way to do this in mavericks. Prior to mavericks we used to delete/Library/Managed Preferences/ and it will reset temporarily but not anymore in mavericks
There are the areas you need to reset for MCX.
Machine MCX
dscl . -mcxdelete /Computers/localhost
For each user
dscl . -mcxdelete /Users/username
root
dscl . -mcxdelete /Users/root
Managed Preferences folder
rm -rfd /Library/Managed Preferences
These will temporarily reset MCX till Mac re-syncs MCX back with JSS.
will these commands also delete preferences managed by WorkGroup Manager?
I have got to try these command once I am back in the office. However, thread starter Franks states that it does not work on their Mavericks environment :(
Hi all,
I've stuggled with this too.
Tbh, I think we're falling fowl of 10.9 aggressive preference caching.
http://hints.macworld.com/article.php?story=20130908042828630
https://groups.google.com/forum/m/#!topic/macenterprise/YgJnfqpyKNs
I've not tried the commands in the thread & then some of the cfprefs commands in the links, but might be worth a shot.
All the above commands plus killall cfprefsd at the very end seems to do the trick. Without adding in that last line some of the settings remain in place under Mavericks, so @bentoms is correct that it seems to be Mavericks' more aggressive preference caching getting in the way.
Nice the cfprefsd seems to be the trick in 10.9, glad to hear it helped.
I figured out these problems with MCX back in 10.6 been using these commands to cleanup MCX since then.
@mm2270 & @jcosta, sometime hunches pay off! :)
I can confirm that deleting /Library/Managed Preferences will work when issuing killall cfprefsd as mentioned by mm2270. Tested this on Mavericks!
My script has been updated to match.
