Hello all.
I had a McAfee installer that installed both the ePO and EPM via a package to the /tmp directory, then ran a post flight script to install them on the system. All of a sudden it seems like the package won't work anymore. I can run the commands through the terminal and it will install, but when I put it back into the package it just doesn't work.
I did some checking and the lines are being read, but nothing is being returned. Before I do more digging, I was wondering if anyone else had run into a problem like this recently.
Thanks.
Chris
Turned out to be a server issue... whew...
Smack Redinger for me.
