Hi all.
I've come across a problem having just updated our iMac lab to 10.8. I tried going down the Configuration profile path, but decided against it for the most part, as it didn't seem to work how we needed it.
So, I've stuck with Managed Preferences, but unfortunately it appears now that no MCX settings apply when a user logs in for the first time. I can fairly well confidently narrow it down to User-level MCX settings that are not applying on first login.
The users authenticate to AD, and all settings come across again on the next login, but it is a bit frustrating in a lab environment. If it makes any difference, the User Experience settings for the AD binding are:
Create mobile account at login - NO
Require confirmation before creating a mobile account - NO
Force local home directory on startup disk - YES
Use UNC path from Active Directory to derive network home location - NO
Network Protocol to be used: SMB
Default user shell: /bin/bash
Anybody know what would cause the failing mcx application?
Cheers,
Nathan
