MDM Capability: No + MDMResponseStatus error 500
  • February 25, 2017
  • 12 replies
  • 586 views
I’ve run into this odd issue with a new laptop that I am trying to enroll into our JSS.
It will not install any profiles at enrollment. I get this error:
Error installing the computer level mdm profile: profiles install for file:'/Library/Application Support/JAMF/tmp/mdm.mobileconfig' and user:'root' returned 500 (The operation couldn’t be completed. (MDMResponseStatus error 500.))
Problem installing MDM profile.
Problem detecting MDM profile after installation.
I renewed our SSL cert last week and I am able to install profiles on other Macs except for this one.
Any advice would be appreciated.
  • February 28, 2017
I resolved this issue by unassigning the device from our DEP portal and then re-assigning it back.
  • February 28, 2017
I just got off a call with JAMF Support.
We got the UDID of the computer and ran a search under Mobile Devices. Delete that entry under Mobile Devices and run the following command.
sudo jamf mdm
  • August 16, 2017
Thank you very much for posting this solution! Had the exact same issue with 6 MacBooks in our system, somehow decided they were going to live in Mobile Devices instead of Computers...
  • September 11, 2017
Some may wonder how this could happen. We had created some manual AppleTV ver3 enrollment profiles. One of our school level techs had double clicked and tried to install it on a Mac mini. After re-imaging it was not pulling down MDM profiles, etc.
Before and after:
adminuser$ sudo jamf mdm -verbose
Password:
Getting management framework from the JSS...
Enabling MDM... verbose: Attempting to install the mdm profile at the computer level.
After searching on Jamf for the Mac Mini's UDID (Located in Apple/About This Mac/System Report/Hardware) under mobile and removing it:
redacted serial:~ adminuser$ sudo jamf mdm -verbose
The computer was successfully enrolled in MDM with the JSS.
Thanks! --Mike
  • January 16, 2018
Ran into this same issue today. Not entirely sure yet how we have about 15 computers enrolled into our mobile category. Had an employee running into an issue where Profilelist and Certificate list were constantly running and prompting with an install MDM profile notification on their mac.
ran a sudo jamf removeMdmProfile followed by a sudo jamf mdm and ran into MDMResponseStatus Error 500.
Was able to look the employees serial number and found it under our mobile and computer lists. Removed it from the mobile devices list and was able to complete a sudo jamf mdm with no errors.
  • March 5, 2019
Thank you,
This problem has been driving me crazy with one MacBook not enrolling. Sure enough it was in the mobile devices.
Thanks
Mark
  • April 16, 2019
So, I had this problem on my machine which I enrolled right after I upgraded our server from 10.7.1 to 10.10 to 10.11.1 over the weekend. And all of our devices were deselected from the PreStage Enrollments they were enrolled in. Slightly annoying, but we only have a handful of PreStage Enrollment configurations. All the modification dates in the configurations were changed to the date/time I edited the configuration. So... wha? (facepalm).
Re-selecting my machine and then allowing the Profile in System Preferences worked and re-enrolled my machine.
  • June 13, 2019
I unfortunately have this problem but couldnt find the UUID or serial listed in the Mobile devices.
jamf Removeframework and deleting the object from the JSS and re-enrolling also didnt fix it.
THinking about it, the only thing I didnt do was delete the relevant mdm profile files/folders (cant remember the location)
Anyone else still struggling?
  • July 9, 2019
Yep still having the issue, have tried all the above. Raising a support case with Jamf - will report back if can find a resolution.
  • July 17, 2019
thanks to @MikeT — was getting this error from a Macmini, searched the UDID in mobile devices and, to my suprise, found the Mac. As soon as I deleted that record, I was able to run sudo jamf manage and everything started working correctly 👍
mani2care
  • March 19, 2021
The perfect solution is without doing the action
sudo jamf mdm -userLevelMdm
sudo Jamf manage
MDM Capability: Yes will be changed
  • September 18, 2023
Did you hear back from Jamf support? I am also having this issue but the devices aren't within Mobile devices. Using apple configurator to manually add devices to ABM then set Jamf as MDM. We then receive the MDMResponseStatus error 500 when using the automated enrolment.
