So, anyways, as a high school student, I am looking to remove an MDM profile that is stored on my computer that has a bunch of restrictions. With 'sudo -s' then typing in 'profiles -R -p com.uni.mdm' I get returned 101: profile is not removable. I then went to a thread regarding how to remove an unremovable mdm profile and came across to do this via nuking the directory that the MDM is stored in. I typed in as bash 3.2#: 'rm -r /var/db/ConfigurationProfiles' and after typing in 'y' a bunch of times in an attempt to remove it, I get that it is not permitted. I have no idea how or why, but I am looking for some help. Thanks for reading this and I hope I can get some help.
MDM profile removal problems
Best answer by prl
@Playdespacito even if you manage to remove the profile it will trigger a flag for your IT team to come track down the hardware and you. I suggest you ask the IT team if they need any student helpers if you want some more freedom on institutionally owned devices available to you. What are you trying to use the macbook for anyhow? it won't run Fortnite or Pubg the way you'll hope.
