MDM showing at Unverified.
  • November 29, 2016
  • 9 views
I'm having an issue with my JSS MDM profile. For some reason if a machine is unmanaged (this is the only way I have tested so far) and then managed again via sudo jamf manage, the MDM profile is not showing as Verified.
Please advise on best way to troubleshoot this issue.
Thank you
David
1 reply
AVmcclint
Forum|alt.badge.img+21
  • January 4, 2017
I'm noticing the same thing happening here, but it's not just the MDM Profile. And it's not always the same profiles on all the machines. I want to say this started happening after I upgraded our JSS to 9.96. If I image a computer under 9.96, ALL the profiles say Unverified. Machines I imaged prior to 9.96 are the ones that are hit or miss on which profiles are verified or not.
