I wanted to monitor if our Macs are doing their Microsoft Defender Full and Quick Scans  properly in Jamf.
As I couldn't find any solution out-of-the-box I came up with a custom script, in case anybody got the same need.
The problem I faced, was that the Mac only saves the state of the last 7 scans (Quick and Full Scans are combined). So let's say you schedule your Quick Scans once per day and your full scans once per week and the user is on vacation only on the "Full-Scan-Day", you have no chance to see, if a full scan never ran or just the week before, but was overwritten by Quick Scans.
That's why I came up with two different timestamps for the full scans, that one timestamp will always be in Jamf, to see when the last full scan ran, the second one might not really be needed, as it only checks the Full Scan within the last 7 scans.
The script might be a bit fragile as it relies on Microsoft to keep the same format for the "mdatp scan list" command, but for now it works :)
You will also need extension attributes in Jamf to collect your results. I collect the following results:
MS Defender - Full Scan - Last Scan Timestamp Overall
   "scan_last_timestemp" from "com.puma.DefenderFullScanMonitoring.plist"
MS Defender - Full Scan - State
   "scan_state" from "com.puma.DefenderFullScanMonitoring.plist"
MS Defender - Full Scan - Timestamp (within last 7 scans)
   "scan_time" from "com.puma.DefenderFullScanMonitoring.plist"
MS Defender - Quick Scan - State
   "scan_state" from "com.puma.DefenderQuickScanMonitoring.plist"
MS Defender - Quick Scan - Timestamp (within last 7 scans)
   "scan_time" from "com.puma.DefenderQuickScanMonitoring.plist"
Feel free to share your comments or improvements on this. Maybe there's even a out-of-the-box solution, which you can point me to.
#!/bin/bash ##################################################################### #Created by RaGL #Modified by # #Subject: Defender Scan Monitoring Script ##################################################################### # # # #VARIABLES########################################################### scan_results=( $(mdatp scan list) ) quick_scan="quick" full_scan="full" quick_scan_plist_path="<PATH>/com.company.DefenderQuickScanMonitoring.plist" full_scan_plist_path="<PATH>/com.company.DefenderFullScanMonitoring.plist" #Scan State Positions in the Array type_pos1="197" type_pos2="166" type_pos3="135" type_pos4="104" type_pos5="73" type_pos6="42" type_pos7="11" #Scan Start Time Positions in the Array time_pos1=( "189" "190" "191" "192" "193" "194" ) time_pos2=( "158" "159" "160" "161" "162" "163" ) time_pos3=( "127" "128" "129" "130" "131" "132" ) time_pos4=( "96" "97" "98" "99" "100" "101" ) time_pos5=( "65" "66" "67" "68" "69" "70" ) time_pos6=( "34" "35" "36" "37" "38" "39" ) time_pos7=( "3" "4" "5" "6" "7" "8" ) #Scan State Positions in the Array state_pos1="202" state_pos2="171" state_pos3="140" state_pos4="109" state_pos5="78" state_pos6="47" state_pos7="16" # #SCRIPT CONTENT###################################################### #last quick scan if [[ ${scan_results[$type_pos1]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos1[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos1})]}) elif [[ ${scan_results[$type_pos2]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos2[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos2})]}) elif [[ ${scan_results[$type_pos3]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos3[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos3})]}) elif [[ ${scan_results[$type_pos4]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos4[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos4})]}) elif [[ ${scan_results[$type_pos5]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos5[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos5})]}) elif [[ ${scan_results[$type_pos6]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos6[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos6})]}) elif [[ ${scan_results[$type_pos7]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos7[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos7})]}) fi #check if there are no quick scans found if [[ -z "$scan_state_quick" ]]; then scan_state_quick="No Quick Scans detected." scan_time_quick="No Quick Scans detected." fi #write quickscan output to a plist defaults write "$quick_scan_plist_path" scan_time -string "$scan_time_quick" defaults write "$quick_scan_plist_path" scan_state -string "$scan_state_quick" #last full scan if [[ ${scan_results[$type_pos1]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos1[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos1})]}) elif [[ ${scan_results[$type_pos2]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos2[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos2})]}) elif [[ ${scan_results[$type_pos3]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos3[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos3})]}) elif [[ ${scan_results[$type_pos4]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos4[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos4})]}) elif [[ ${scan_results[$type_pos5]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos5[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos5})]}) elif [[ ${scan_results[$type_pos6]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos6[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos6})]}) elif [[ ${scan_results[$type_pos7]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos7[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos7})]}) fi #check if there are no full scans found if [[ -z "$scan_state_full" ]]; then scan_state_full="No Full Scans detected within last 7 scans." scan_time_full="No Full Scans detected within last 7 scans." fi #set a timestamp for the last full scan, to always see in Jamf when the last full scan was done; even if there was no timestamp within the last 7 scans year_only=$(echo $scan_time_full | awk '{print $3}') month_only=$(echo $scan_time_full | awk '{print $1}') day_only=$(echo $scan_time_full | awk '{print $2}' | cut -c 1,2) time_only=$(echo $scan_time_full | awk '{print $5}') if [[ $month_only == "Jan" ]]; then month_only="01" elif [[ $month_only == "Feb" ]]; then month_only="02" elif [[ $month_only == "Mar" ]]; then month_only="03" elif [[ $month_only == "Apr" ]]; then month_only="04" elif [[ $month_only == "May" ]]; then month_only="05" elif [[ $month_only == "Jun" ]]; then month_only="06" elif [[ $month_only == "Jul" ]]; then month_only="07" elif [[ $month_only == "Aug" ]]; then month_only="08" elif [[ $month_only == "Sep" ]]; then month_only="09" elif [[ $month_only == "Oct" ]]; then month_only="10" elif [[ $month_only == "Nov" ]]; then month_only="11" elif [[ $month_only == "Dec" ]]; then month_only="12" fi #combine the variables to match the date format for Jamf: YYYY-MM-DD hh:mm:ss scan_timestamp_last_full=$(echo "$year_only-$month_only-$day_only $time_only") #write quickscan output to a plist defaults write "$full_scan_plist_path" scan_time -string "$scan_time_full" defaults write "$full_scan_plist_path" scan_state -string "$scan_state_full" defaults write "$full_scan_plist_path" scan_last_timestemp -string "$scan_timestamp_last_full"
Small correction for when the "$scan_state_full" is empty:
#!/bin/bash ##################################################################### #Created by RaGL #Modified by # #Subject: Defender Scan Monitoring Script ##################################################################### # # # #VARIABLES########################################################### scan_results=( $(mdatp scan list) ) quick_scan="quick" full_scan="full" quick_scan_plist_path="<PATH>/com.company.DefenderQuickScanMonitoring.plist" full_scan_plist_path="<PATH>/com.company.DefenderFullScanMonitoring.plist" #Scan State Positions in the Array type_pos1="197" type_pos2="166" type_pos3="135" type_pos4="104" type_pos5="73" type_pos6="42" type_pos7="11" #Scan Start Time Positions in the Array time_pos1=( "189" "190" "191" "192" "193" "194" ) time_pos2=( "158" "159" "160" "161" "162" "163" ) time_pos3=( "127" "128" "129" "130" "131" "132" ) time_pos4=( "96" "97" "98" "99" "100" "101" ) time_pos5=( "65" "66" "67" "68" "69" "70" ) time_pos6=( "34" "35" "36" "37" "38" "39" ) time_pos7=( "3" "4" "5" "6" "7" "8" ) #Scan State Positions in the Array state_pos1="202" state_pos2="171" state_pos3="140" state_pos4="109" state_pos5="78" state_pos6="47" state_pos7="16" # #SCRIPT CONTENT###################################################### #last quick scan if [[ ${scan_results[$type_pos1]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos1[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos1})]}) elif [[ ${scan_results[$type_pos2]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos2[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos2})]}) elif [[ ${scan_results[$type_pos3]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos3[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos3})]}) elif [[ ${scan_results[$type_pos4]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos4[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos4})]}) elif [[ ${scan_results[$type_pos5]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos5[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos5})]}) elif [[ ${scan_results[$type_pos6]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos6[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos6})]}) elif [[ ${scan_results[$type_pos7]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos7[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos7})]}) fi #check if there are no quick scans found if [[ -z "$scan_state_quick" ]]; then scan_state_quick="No Quick Scans detected." scan_time_quick="No Quick Scans detected." fi #write quickscan output to a plist defaults write "$quick_scan_plist_path" scan_time -string "$scan_time_quick" defaults write "$quick_scan_plist_path" scan_state -string "$scan_state_quick" #last full scan if [[ ${scan_results[$type_pos1]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos1[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos1})]}) elif [[ ${scan_results[$type_pos2]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos2[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos2})]}) elif [[ ${scan_results[$type_pos3]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos3[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos3})]}) elif [[ ${scan_results[$type_pos4]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos4[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos4})]}) elif [[ ${scan_results[$type_pos5]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos5[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos5})]}) elif [[ ${scan_results[$type_pos6]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos6[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos6})]}) elif [[ ${scan_results[$type_pos7]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos7[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos7})]}) fi #set a timestamp for the last full scan, to always see in Jamf when the last full scan was done; even if there was no timestamp within the last 7 scans year_only=$(echo $scan_time_full | awk '{print $3}') month_only=$(echo $scan_time_full | awk '{print $1}') day_only=$(echo $scan_time_full | awk '{print $2}' | cut -c 1,2) time_only=$(echo $scan_time_full | awk '{print $5}') if [[ $month_only == "Jan" ]]; then month_only="01" elif [[ $month_only == "Feb" ]]; then month_only="02" elif [[ $month_only == "Mar" ]]; then month_only="03" elif [[ $month_only == "Apr" ]]; then month_only="04" elif [[ $month_only == "May" ]]; then month_only="05" elif [[ $month_only == "Jun" ]]; then month_only="06" elif [[ $month_only == "Jul" ]]; then month_only="07" elif [[ $month_only == "Aug" ]]; then month_only="08" elif [[ $month_only == "Sep" ]]; then month_only="09" elif [[ $month_only == "Oct" ]]; then month_only="10" elif [[ $month_only == "Nov" ]]; then month_only="11" elif [[ $month_only == "Dec" ]]; then month_only="12" fi #combine the variables to match the date format for Jamf: YYYY-MM-DD hh:mm:ss scan_timestamp_last_full=$(echo "$year_only-$month_only-$day_only $time_only") #check if there are no full scans found if [[ -z "$scan_state_full" ]]; then scan_state_full="No Full Scans detected within last 7 scans." scan_time_full="No Full Scans detected within last 7 scans." fi #write quickscan output to a plist defaults write "$full_scan_plist_path" scan_time -string "$scan_time_full" defaults write "$full_scan_plist_path" scan_state -string "$scan_state_full" defaults write "$full_scan_plist_path" scan_last_timestemp -string "$scan_timestamp_last_full"
Final adjustment:
#!/bin/bash ##################################################################### #Created by RaGL #Modified by # #Subject: Defender Scan Monitoring Script ##################################################################### # # # #VARIABLES########################################################### scan_results=( $(mdatp scan list) ) quick_scan="quick" full_scan="full" quick_scan_plist_path="<PATH>/com.company.DefenderQuickScanMonitoring.plist" full_scan_plist_path="<PATH>/com.company.DefenderFullScanMonitoring.plist" #Scan State Positions in the Array type_pos1="197" type_pos2="166" type_pos3="135" type_pos4="104" type_pos5="73" type_pos6="42" type_pos7="11" #Scan Start Time Positions in the Array time_pos1=( "189" "190" "191" "192" "193" "194" ) time_pos2=( "158" "159" "160" "161" "162" "163" ) time_pos3=( "127" "128" "129" "130" "131" "132" ) time_pos4=( "96" "97" "98" "99" "100" "101" ) time_pos5=( "65" "66" "67" "68" "69" "70" ) time_pos6=( "34" "35" "36" "37" "38" "39" ) time_pos7=( "3" "4" "5" "6" "7" "8" ) #Scan State Positions in the Array state_pos1="202" state_pos2="171" state_pos3="140" state_pos4="109" state_pos5="78" state_pos6="47" state_pos7="16" # #SCRIPT CONTENT###################################################### #last quick scan if [[ ${scan_results[$type_pos1]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos1[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos1[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos1})]}) elif [[ ${scan_results[$type_pos2]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos2[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos2[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos2})]}) elif [[ ${scan_results[$type_pos3]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos3[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos3[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos3})]}) elif [[ ${scan_results[$type_pos4]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos4[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos4[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos4})]}) elif [[ ${scan_results[$type_pos5]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos5[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos5[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos5})]}) elif [[ ${scan_results[$type_pos6]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos6[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos6[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos6})]}) elif [[ ${scan_results[$type_pos7]} = $quick_scan ]]; then scan_time_quick=$(echo ${scan_results[$(echo ${time_pos7[0]})]}) scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[1]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[2]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[3]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[4]})]})" scan_time_quick+=" $(echo ${scan_results[$(echo ${time_pos7[5]})]})" scan_state_quick=$(echo ${scan_results[$(echo ${state_pos7})]}) fi #check if there are no quick scans found if [[ -z "$scan_state_quick" ]]; then scan_state_quick="No Quick Scans detected." scan_time_quick="No Quick Scans detected." fi #write quickscan output to a plist defaults write "$quick_scan_plist_path" scan_time -string "$scan_time_quick" defaults write "$quick_scan_plist_path" scan_state -string "$scan_state_quick" #last full scan if [[ ${scan_results[$type_pos1]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos1[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos1[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos1})]}) elif [[ ${scan_results[$type_pos2]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos2[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos2[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos2})]}) elif [[ ${scan_results[$type_pos3]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos3[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos3[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos3})]}) elif [[ ${scan_results[$type_pos4]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos4[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos4[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos4})]}) elif [[ ${scan_results[$type_pos5]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos5[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos5[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos5})]}) elif [[ ${scan_results[$type_pos6]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos6[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos6[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos6})]}) elif [[ ${scan_results[$type_pos7]} = $full_scan ]]; then scan_time_full=$(echo ${scan_results[$(echo ${time_pos7[0]})]}) scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[1]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[2]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[3]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[4]})]})" scan_time_full+=" $(echo ${scan_results[$(echo ${time_pos7[5]})]})" scan_state_full=$(echo ${scan_results[$(echo ${state_pos7})]}) fi #set a timestamp for the last full scan, to always see in Jamf when the last full scan was done; even if there was no timestamp within the last 7 scans year_only=$(echo $scan_time_full | awk '{print $3}') month_only=$(echo $scan_time_full | awk '{print $1}') day_only=$(echo $scan_time_full | awk '{print $2}' | cut -c 1,2) time_only=$(echo $scan_time_full | awk '{print $5}') if [[ $month_only == "Jan" ]]; then month_only="01" elif [[ $month_only == "Feb" ]]; then month_only="02" elif [[ $month_only == "Mar" ]]; then month_only="03" elif [[ $month_only == "Apr" ]]; then month_only="04" elif [[ $month_only == "May" ]]; then month_only="05" elif [[ $month_only == "Jun" ]]; then month_only="06" elif [[ $month_only == "Jul" ]]; then month_only="07" elif [[ $month_only == "Aug" ]]; then month_only="08" elif [[ $month_only == "Sep" ]]; then month_only="09" elif [[ $month_only == "Oct" ]]; then month_only="10" elif [[ $month_only == "Nov" ]]; then month_only="11" elif [[ $month_only == "Dec" ]]; then month_only="12" fi #combine the variables to match the date format for Jamf: YYYY-MM-DD hh:mm:ss scan_timestamp_last_full=$(echo "$year_only-$month_only-$day_only $time_only") #Add values to the plist #check if there are no full scans found if [[ -z "$scan_state_full" ]]; then scan_state_full="No Full Scans detected within last 7 scans." scan_time_full="No Full Scans detected within last 7 scans." else defaults write "$full_scan_plist_path" scan_last_timestemp -string "$scan_timestamp_last_full" fi #write scan output to a plist defaults write "$full_scan_plist_path" scan_time -string "$scan_time_full" defaults write "$full_scan_plist_path" scan_state -string "$scan_state_full"
The last time I deployed Defender, I used this to keep an eye on devices while onboarding:
#!/bin/bash # EA to report Defender's last scan date in days # by reporting an integer instead of a date string, we can use Jamf's Greater Than # string output: "Jan 05 2023 at 03:18:39 PM" # gnarly sed etc to sanitize output last_scan_date_str=$(/usr/local/bin/mdatp scan list | awk -F "Scan Start Time:" ' { print $2; exit }' | tr -d "at,:" | sed 's/^[[:space:]]*//' | sed 's/...$//') # convert to epoch time: "1525351519" last_scan_date=$(date -j -f "%b %d %Y %H %M %S" "$last_scan_date_str" "+%s") currentDate=$(date +%s) # expr is antiquated, so we can simply ((...)) difference=$((currentDate - last_scan_date)) days=$((difference / 86400)) # report results in days echo "<result>$days</result>"
Thank you for your answer.
Got it, but for me it was important to keep track and make sure, that both Full Scan and Quick Scan run on a regular basis and are recorded in Jamf.
