Hello,
I would like to hide the window that asks whether to send diagnostic data when opening Microsoft Edge.
After some research, I found the Edge Policy available in Jamf (com.microsoft.Edge). I added DiagnosticData and configured it. The profile is applied. Unfortunately, it doesn’t work—the window still opens. The other configured settings are applied.
Edge version : 132
Edge Policy :
The Diagnostic window :
Thanks
You need to select the option Off to hide this window
I tried, it doesn't work. I also tested the other options, same result.
I found an alternative. By accepting the diagnostic data, a new file is created in ~/Library/Application Support/Microsoft Edge/First Run.
With a script that run at each session startup (Guest session in my case), it works, there’s no more window Diagnostic Data.
#!/bin/bash # Définir le chemin du dossier et du fichier dossier="/Users/Guest/Library/Application Support/Microsoft Edge" fichier="$dossier/First Run" # Créer le dossier "Microsoft Edge" s'il n'existe pas déjà mkdir -p "$dossier" # Créer un fichier "First Run" dans ce dossier touch "$fichier" # Modifier le propriétaire du dossier et de son contenu chown -R Guest "$dossier" # Définir les permissions : # - Propriétaire : lecture-écriture (rwx pour les dossiers, rw- pour les fichiers) # - Groupe et Everyone : accès interdit (---) chmod -R 700 "$dossier"
