I'm trying to create a plist and add it using a config profile. I found the below 2 that I tried to modify, but after deploying the profile, Teams still doesn't autostart.
teams.plist · GitHub
Microsoft Teams forced Auto-Start for all Users - Jamf Nation Community - 248530
This is the solution we are using.
Where are you creating that?
as a policy that runs on all machines ongoing and make it available offline
We're using a simple Configuration Profile for Login Items - note: the slash at the end is important:
I also use this option. Although "Hide" doesn't seem to work for some reason.
I guess the other option is scripting something like this:
https://community.jamf.com/t5/jamf-pro/adding-an-app-to-login-items/m-p/122779/highlight/true#M111896
