Model shows the Model Identifier in Hardware inventory for M1 Pro and M1 Max device
  • December 13, 2021
  • 8 replies
  • 66 views
karthikeyan_mac
Forum|alt.badge.img+20
Model populates the Model Identifier value instead of Model for M1 Pro and M1 Max MacBook Pros.  The M1 and Intel devices inventory shows the Model like "MacBook Air (M1, 2020), MacBook Pro (15-inch, 2018) etc.
We are running Jamf Pro 10.34.1.
Is this a bug or known issue ?
Thanks & Regards,
Karthikeyan
sdagley
  • December 13, 2021
@karthikeyan_mac This is normal until your Jamf Pro version is one updated to recognize the new models.
karthikeyan_mac
  • December 13, 2021
@sdagley I missed mentioning the Jamf Pro version in the post. Edited it now.
We are running the latest version (10.34.1) of Jamf Pro.
sdagley
  • December 13, 2021
@karthikeyan_mac Updating Model IDs in Jamf Pro seems to be a low priority for updates, so it's not surprising 10.34.1 hasn't been updated (I believe the only change from 10.34.0 was the CVE-2021-44228 fix). It's likely 10.35.0 will recognize those models.
karthikeyan_mac
  • December 22, 2021
Thank you. I added the extension attribute to fetch the information.
karthikeyan_mac
  • December 22, 2021
Extension Attribute to fetch the Hardware Model.
#!/bin/bash cpuArch=`arch` if [[ $cpuArch == "i386" ]]; then model=$(curl -s https://support-sp.apple.com/sp/product?cc=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}' | cut -c 9-) | sed 's|.*<configCode>\\(.*\\)</configCode>.*|\\1|') elif [[ $cpuArch == *"arm64"* ]]; then model=$(/usr/libexec/PlistBuddy -c 'Print 0:product-name' /dev/stdin <<< "$(ioreg -arc IOPlatformDevice -k product-name)" 2> /dev/null) fi echo "<result>$model</result>"
donmontalvo
Forum|alt.badge.img+36
  • December 23, 2021
(never mind, misunderstood the question)
  • March 24, 2022
Jamf Inventory shows wrong year for various models.   "About this Mac" show 2017, which is correct.  Jamf Pro show it as 2015 model?  IDK
sdagley
  • March 24, 2022
@jttavares I believe Jamf Pro just goes by the Model Identifier, which Apple has been known to re-use occasionally. About This Mac may use a more precise method of acquiring the model name.
