Monthly TCCC Prompts - macOS v15
  • September 24, 2024
  • 29 replies
  • 455 views
Show first post
motorcitymike13
To the above, once the profile is deployed on 15.1 and MacOS os upgraded afterwards to 15.2, all seems to work fine. But when one deploys the profile AFTER the upgrade to 15.2, it doesn't seem to suppress screen capture alerts.
Are you using a Jamf restrictions profile? The new keys were added to the Restrictions profile options in Jamf Pro 11.12.x. In our case, we had already created and deployed custom profiles for four options that were added, resulting in duplicate keys with opposing values. I can elaborate on how we fixed this issue, if it is pertinent.
  • January 1, 2025
Actually, I did test Restrictions profile options in Jamf Pro 11.12.x. which did seem to work for me on 15.2 but problems is this payload comes with lots of default keys I don't want within my payload.
So guess a custom profile would be best, problem is it doesn't seem to work for me when deploying it on 15.2
  • January 1, 2025
While it may not be pertinent I would be happy if you can elaborate on how you handled those duplicate keys.
motorcitymike13
This is specific for our environment:
1. Change scope of “Restrictions” profile from “All Targets” to “Specific Computers” and scope targets:
Targets:
- Add 12.0 Machines
- Add 13.0 Machines
- Add 14.0 Machines
Exclusions:
- Remove “15.0 and Newer Machines”
2. Clone Configuration Profile “Restrictions-Sequoia” and name it “Restrictions-Sequoia 15.2”
- Update version date in Description
- Update Category if needed
 - Remove any scoped groups so that it has only a target of a test machine.
- Edit Restrictions > Functionality
- Check box for “Bypass screen capture alert (macOS 15.1 or later)”
- Uncheck box for “Allow Apple Intelligence: Mail Summaries (macOS 15.1 or later)”
- Uncheck box for “Allow users to log in to external intelligence services (macOS 15.2 or later, supervised)”
- Uncheck box for “Allow integration with external intelligence services (macOS 15.2 or later, supervised)”
- Save “Restrictions-Sequoia 15.2”
3. Find the profile identifier from the test machine’s record.
4. Create a Smart Group “Profile - Restrictions-Sequoia 15.2 Installed” based criterion (example ID): Profile Identifier “is” ABCD1234-EF56-449F-9573-6BB705410C9D
5. Edit  “Restrictions-Sequoia”
- Edit Scope to Exclude “Profile - Restrictions-Sequoia 15.2 Installed”
- Save “Restrictions-Sequoia”
6. Exclude “Profile - Restrictions-Sequoia 15.2 Installed” from:
AI-Disable External Intelligence Integrations
AI-Disable External Intelligence Logins
AI-Disable Mail Summary
Disable Screen Access Request User Notifications
7. Edit “Restrictions-Sequoia 15.2”
- Scope to Smart Group “15.2 and Newer Machines”
