Does anyone know how to remove/delete an identity preference from the keychain by script?
We set security identity preferences by:
security set-identity-preference -s
Now how would you delete one? the man page for security only specifies:
set-identity preferences
get-identity preferences
Anything? Thanks in advance!
Has anyone figured out how to delete identity preferences via terminal. I know how to do it through Keychain Access but need to do this on mass.
I ran a quick test, and it looks like running
security set-identity-preference -n -s "name of service"
effectively removes the identity preference. The -n flag is to clear an existing setting.
lmao thank you. I tried that and it didn't do anything to only realize I didn't put sudo in front so that it would effect the System.keychain :D.
sudo security = System.keychain
security = login.keychain for the user that ran the command
This look like a command I need to run on a subset of older Macs because a new service is broken on Macs with an older ID Pref.
From the above if I run this as a command policy or a script from jamf will it run in the user or system context?
