Hi-
After updating our Netboot image to 10.6.3 (10D2125) and our standard 10.6.3 build to the same in Imaging, I’ve got a brand new i5-based 15” MBP that is kernel panicing whenever you log out or restart it with that build of the OS.
I thought, ok, let’s rule out hardware so I grabbed the discs that came with it and rolled over the installed OS with the one on disk. After checking the build number, I’m a bit perplexed. It’s 10.6.3 10D2084, which is not what is listed on Apple’s KB for shipping OSes on Intel-based Macs ( http://support.apple.com/kb/ht1159?locale=en_US)
Has anyone else run into this? Does Apple actually have like 3 forks of 10.6.3 running out there and you have to run hardware specific builds on each one (rather than the latest build on all of them)?
Thanks
j
Jared F. Nichols
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
