Mount and Unmount SMB script
  • Nov 12, 2025 6:30 AM UTC
  • 102 views
Kel11
Hi Everyone,
Need your help if you have a script that can mount and unmount SMB the can be use as repository of screenshots
Thank you.
1 reply
h1431532403240
Hi Kel11,
Happy to help with SMB mount/unmount scripts! Below are scripts you can use with Jamf Pro to mount SMB shares for storing screenshots or any other files.
Mount SMB Share Script
This script can be deployed via Jamf Pro policy (at login, via Self Service, or triggered by custom event):
# Mount SMB Share Script for Jamf Pro
# Use with policy parameters or modify variables directly
# Variables - modify these or use Jamf Pro script parameters
protocol="smb"
serverName="${4:-your.server.com}" # Parameter 4 in Jamf Pro
shareName="${5:-Screenshots}" # Parameter 5 in Jamf Pro
# Get current logged-in user
currentUser=$(/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }')
uid=$(id -u "${currentUser}")
# Build mount path
mountPath="${protocol}://${serverName}/${shareName}"
# Function to run commands as logged-in user
runAsUser() {
/usr/bin/launchctl asuser "${uid}" sudo -u "${currentUser}" "$@"
# Allow connections to unknown servers (prevents authentication prompts on first connect)
defaults write /Library/Preferences/com.apple.NetworkAuthorization AllowUnknownServers -bool YES
# Check if already mounted, if not, mount the share
runAsUser osascript <<EOT
on listMountedDisks()
list disks
end listMountedDisks
if (listMountedDisks() does not contain "${shareName}") then
try
mount volume "${mountPath}"
on error errMsg
display dialog "Failed to mount ${shareName}: " & errMsg buttons {"OK"} default button "OK"
end try
end if
EOT
# Verify mount was successful
if mount | grep -q "/Volumes/${shareName}"; then
echo "Successfully mounted ${shareName}"
echo "Failed to mount ${shareName}"
exit 1
Unmount SMB Share Script
# Unmount SMB Share Script for Jamf Pro
# Variables
shareName="${4:-Screenshots}" # Parameter 4 in Jamf Pro
runAsUser() {
# Check if share is mounted
# Unmount using diskutil (cleaner method)
/usr/sbin/diskutil unmount "/Volumes/${shareName}"
# Alternative: Force unmount if needed
# /usr/sbin/diskutil unmount force "/Volumes/${shareName}"
if [ $? -eq 0 ]; then
echo "Successfully unmounted ${shareName}"
echo "Failed to unmount ${shareName}"
exit 1
echo "${shareName} is not currently mounted"
Combined Mount/Unmount Script with Toggle
If you want a single script that can do both:
# Mount/Unmount SMB Share Toggle Script
# Parameter 4: action (mount/unmount)
# Parameter 5: server name
# Parameter 6: share name
action="${4:-mount}"
serverName="${5:-your.server.com}"
shareName="${6:-Screenshots}"
protocol="smb"
runAsUser() {
case "${action}" in
mount)
echo "${shareName} is already mounted"
runAsUser osascript -e "mount volume \"${mountPath}\""
sleep 2
exit 1
unmount)
echo "${shareName} is not mounted"
echo "Invalid action. Use 'mount' or 'unmount'"
exit 1
esac
Deployment Tips:
  1. In Jamf Pro, go to Settings > Computer Management > Scripts and add your script
  2. Create a Policy and attach the script
  3. Set parameters:
    • Parameter 4: Server name (e.g., fileserver.company.com)
    • Parameter 5: Share name (e.g., Screenshots)
  4. For screenshot repository usage, trigger the mount policy at Login or via Self Service
Authentication Options:
  • Kerberos (AD-bound Macs): The script will automatically use the user's Kerberos ticket if the Mac is bound to AD
  • Keychain: If the user connects manually once and saves credentials to Keychain, subsequent mounts will be automatic
  • Hardcoded credentials (not recommended for security): You can use mount_smbfs //username:password@server/share /Volumes/ShareName
For macOS Screenshot Settings:
To automatically save screenshots to the mounted SMB share, you can add this to your script after mounting:
# Set screenshot location to the mounted share
runAsUser defaults write com.apple.screencapture location "/Volumes/${shareName}"
runAsUser killall SystemUIServer
Let me know if you need any modifications or have questions about the implementation!
