Moving clients between distribution points
  • May 14, 2013
  • 13 views
Is it possible to move clients between distribution points? We have no distribution points in our environment today, but I would like to add DP's in the future. If a client is relocated to a different facility, can their agent be easily reconfigured to point to the site local DP?
  • Employee
  • May 14, 2013
You can setup Network Segments in Casper and based on their IP set a default Distribution Point Server, Netboot Server, and SUS. I guess it depends on your environment and how your network is configured as to if that would work.
  • May 14, 2013
Yep, just scope by network segment when it comes to the distribution point. We have all kinds of movement in our buildings and the clients use which ever DP is assigned to the building they are in at that time.
JSS> Settings> Network Segments
[external image link](http://postimage.org/)
