Hello All,
I am looking for a solution to update MS Office using terminal Command or from a Script.
Is it possible to run AutoUpdate.app from the following location i.e. /Library/Application Support/Microsoft/MAU2.0/Microsoft AutoUpdate.app using terminal command or Script?
Is there any silent parameter to invoke the AutoUpdate.app using CLI. and then look for available updates. If updates available then is it possible to update them using command line or Script?
Kindly Advice.
Regards,
SonuW
