We have just finished our engagement to setup Jamf connect. While setup with new machines works fine (azure login appears during provisioning as expected), deployment to existing machines is causing multiple issues.
1) Connect/azure login will not appear on filevault 2 encrypted machines. Turning filevault 2 off allows the connect/azure login to appear
2) Syncing accounts at boot with causes a login loop with a password mismatch. When this occurs, it wipes out the user's keychain
3) SSO is not working video-20190327-145114-a9132df3.mp4 uploaded
Be the first to reply!
