Need a Script to add ipads to a static group.
  • June 22, 2017
  • 6 replies
  • 51 views
Let the title say I need help finding a script that will add ipads to a static group. I found script for computer but not for ipads.
  • June 22, 2017
Post the script you found for adding Macs here and I'm sure it would only take a small amount of editing to make it work with iPads/iOS devices. I assume it's an API script that takes an input file (csv, txt, etc) as the source.
  • June 22, 2017
Try the JSS MUT, available from the Mac App Store. They just added this functionality. To my knowledge, this is developed by a jamf (or at least former jamf) employee. https://itunes.apple.com/us/app/the-mut/id1133234759?mt=12
  • June 22, 2017
Thanks ! @mm2270 for the quick response! Below is link to the script:
https://www.jamf.com/jamf-nation/discussions/10471/script-to-add-computers-to-static-group-by-computer-name
  • June 22, 2017
Here is a discussion I came across a few weeks ago for iOS static groups:
https://www.jamf.com/jamf-nation/discussions/5505/static-groups-by-class-enrollment
You will have to do some heavy modification if your are not a school (because it takes data from a SIS)
  • June 22, 2017
@twall Awesome!! that worked like a champion!
I am new to Jamf, how do you run these scripts to make life easier? It would be nice not having to select over 2800 iPads to put into specific static groups.
