Need API help- filling extension attribute text field
  • October 12, 2022
  • 6 replies
  • 115 views
Hey gang-
Thought I had this one locked up, but was woefully incorrect. I'm trying to put something in Self Service that allows a tech to input a serial number and ticket number, and writes that into an extension attribute for the record.
Everything's fine until it comes to populating the EA, then it returns error code 400. I'm assuming the format for the EA input is wrong.
I've seen a few articles doing the same thing on JAMFNation, but they're a little on the old side, and some of them have unanswered questions.
Here's what I have so far:
#get device serial number serialNumber="$(osascript -e 'display dialog "Please enter the Serial Number" default answer "" with title "Serial Number" giving up after 86400 with text buttons {"OK"} default button 1' -e 'return text returned of result')" echo "serial number entered is $serialNumber" #get the ticket number ticketNumber="$(osascript -e 'display dialog "Please enter the Ticket Number" default answer "" with title "Service Now Ticket Number" giving up after 86400 with text buttons {"OK"} default button 1' -e 'return text returned of result')" echo "ticket number entered is $ticketNumber" echo "<computer><extension_attributes><extention_attribute><id>$eaID</id><name>$eaName</name><type>String</type><multi_value>false</multi_value><value>$ticketNumber</value></extension_attribute></extension_attributes></computer>" | curl -X PUT -fku $jssUser:$jssPass -d @- "$jssURL/JSSResource/computers/serialnumber/$serialNumber/subset/extension_attributes" -H "Content-Type: text/xml"
Best answer by mdp
My quick go at it — seems to work. Potentially has the issue with the Jamf username/password hardcoded into the script (depending how it's being used), but you can always ask for those via Applescript as well.
#!/bin/bash #Matthew Prins 2022 #https://github.com/MatthewPrins/Jamf/ ###################### #Editable variables #Jamf credentials username="xxxxxx" password="xxxxxx" url="https://xxxxxx.jamfcloud.com" #Computer Extension Attribute number -- found in URL on group's page extensionattributeid="7" ###################### #Token function -- based on https://developer.jamf.com/jamf-pro/docs/jamf-pro-api-overview getBearerToken() { response=$(curl -s -u "$username":"$password" "$url"/api/v1/auth/token -X POST) bearerToken=$(echo "$response" | plutil -extract token raw -) tokenExpiration=$(echo "$response" | plutil -extract expires raw - | awk -F . '{print $1}') tokenExpirationEpoch=$(date -j -f "%Y-%m-%dT%T" "$tokenExpiration" +"%s") } #get token getBearerToken #get device serial number serialNumber="$(osascript -e 'display dialog "Please enter the Serial Number" default answer "" with title "Serial Number" giving up after 86400 with text buttons {"OK"} default button 1' -e 'return text returned of result')" echo "serial number entered is $serialNumber" #get the ticket number ticketNumber="$(osascript -e 'display dialog "Please enter the Ticket Number" default answer "" with title "Service Now Ticket Number" giving up after 86400 with text buttons {"OK"} default button 1' -e 'return text returned of result')" echo "ticket number entered is $ticketNumber" curl --silent \\ --request PUT \\ --url $url/JSSResource/computers/serialnumber/$serialNumber \\ --header "Authorization: Bearer $bearerToken" \\ --header 'Accept: application/xml' \\ --header 'Content-Type: application/xml' \\ --data "<computer><extension_attributes><extension_attribute><id>$extensionattributeid</id><value>$ticketNumber</value></extension_attribute></extension_attributes></computer>"
pbenware1
  • October 12, 2022
Don't have an answer, but a rather a question about the serial # dialog piece (not criticizing, just curious);
What's the reasoning for having the tech manually enter the Serial?  If this is running from Self Service, you could have the script collect the serial into a variable and pass that without needing the serial # dialog piece.
  • October 12, 2022
Valid question- the idea is that a tech runs it from their Mac, so that it doesn't have to be scoped to a user. This also cuts down on giving unnecessary access to the JSS. So far it's been a hit. We have a Self Heal in there, too.
  • October 12, 2022
pbenware1
  • October 12, 2022
Ah.  makes sense.  Thank you.
  • October 13, 2022
Below script will work to adjust a static EA value of choice.
Let me know in case of questions but this should do the trick.
Serial=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}')
jamfUser=TO FILL
jamfPass=TO FILL
jamfUrl=TO FILL
# Get JAMF computer ID
MacID=$(curl -H "Accept: text/xml" -sfku "${jamfUser}:${jamfPass}" "${jamfUrl}/JSSResource/computers/serialnumber/$Serial/subset/general" | xmllint --format - 2>/dev/null | awk -F'>|<' '/<id>/{print $3}')
Echo $MacID
Echo $Serial
# Update JAMF Extension Attribute to "VALUE"
curl -sku $jamfUser:$jamfPass $jamfUrl/JSSResource/computers/id/$MacID -X PUT -H "Content-type: application/xml" -d "<computer><extension_attributes><extension_attribute><name>NAME OF EA</name><value>VALUE TO CHANGE</value></extension_attribute></extension_attributes></computer>"
jamf recon
  • October 13, 2022
This did the trick! Thanks much!
