What I was doing in the past to enable the USB services doesn't seem to work on the newer version of the client. I need to update student's client because their current version does not work on our version of Horizon now.
Previously I did the following after install.
sudo chmod 755 "/Applications/VMware Horizon Client.app/Contents/Library/InitUsbServices.tool"
sudo "/Applications/VMware Horizon Client.app/Contents/Library/InitUsbServices.tool" &>/dev/null
Has anyone had any luck enabling the USB Remote Services for standard users?
