Need help with diskutil list
  • February 21, 2013
  • 34 replies
  • 107 views
Forum|alt.badge.img+21
Hi guys
I've been trying to get the IDENTIFIER of a usb stick plugged in so i can use disk1s1 as a variable
Im having problems cutting out the spaces and i was wondering if anyone knows how to just get disk1s1?
This is what i have so far
diskutil list | grep RALLY | grep disk 1: Windows_FAT_32 RALLY2 64GB 64.2 GB disk1s1
Best answer by kitzy
You should just be able to do this:
diskutil list | grep RALLY | awk '{print $7}'
Tested fine on my machine using Macintosh HD instead of RALLY.
kitzy
  • February 21, 2013
  • February 21, 2013
thanks very much this worked :)
kitzy
  • February 21, 2013
No problem! Glad I could help.
  • February 21, 2013
Another way which may be a little more reliable would be to get the last column of output with $NF and also use awk's regex matching in one shot.
diskutil list | awk '/RALLY/{print $NF}'
You can replace RALLY with any other disk name, including ones with spaces. No need to escape the spaces:
diskutil list | awk '/Recovery HD/{print $NF}'
  • February 26, 2013
Thanks Mike. I uploaded a script to JAMFNATION so i will contact my account manager to relace it with an updated version :)
  • February 26, 2013
Unfortunately i've hit another stumbling block
I need to be able to pass the Mount Point as another variable.
this is what i put in
diskutil info disk1s1 | awk -F"/" '/Mount Point/{ print $NF }'
and i get the output
RALLY2 64GB
As you can see my pen drive has a space in it. If i try to use this as a variable it fails because it is looking for /Volumes/RALLY2 64GB/
Can anyone help?
  • February 26, 2013
Just quote the variable when you need to use it -
driveName=`diskutil info disk1s1 | awk -F"/" '/Mount Point/{ print $NF }'`
echo "$driveName"
  • February 26, 2013
Thanks Mike
Unfortunately when i do that i get
RALLY2 64GB
what i am trying to do is get RALLY2 64GB
if i do
echo "$driveName" | sed 's/ /\\ /g'
that gives me RALLY2 64GB
but i am having problems passing that on as a variable because i am wanting to do this command
# Sophos Anti-Virus scan the disk
savscan=`/usr/bin/sweep /Volumes/"$diskName" | grep ">>> Virus" | cut -d"'" -f3 | cut -c 16- | sed 's/ /\\ /g'`
# trigger the virus file to show the gui virus alert to the user
touch "$savscan"
this unfortunately returns
/Volumes/RALLY2 64GB/eicar.com.txt: No such file or directory
  • February 26, 2013
Not sure if it'll help, but you can try moving the open quote mark to the left of /Volumes like this:
savscan=`/usr/bin/sweep "/Volumes/$diskName" | grep ">>> Virus" | cut -d"'" -f3 | cut -c 16- | sed 's/ / /g'`
That quotes the entire string from the /Volumes line, which may prevent the error you're getting.
  • February 26, 2013
unfortunately this brings back
touch: /Volumes/RALLY2 64GB/eicar.com.txt
  • February 26, 2013
If i touch the file manually it works fine
  • February 26, 2013
OK, as I don't have anything I can really test your script against, I'm just taking some educated guesses here. but try echoing the results of grabbing the disk name back into a second variable and use that instead.
DiskName=`echo $driveName`
savscan=`/usr/bin/sweep "/Volumes/$DiskName" | grep ">>> Virus" | cut -d"'" -f3 | cut -c 16- | sed 's/ / /g'`
touch "$savscan"
If that doesn't work, not sure what else to tell you. Perhaps someone that uses Sophos can help out with testing. Its hard for me to know how the /usr/bin/sweep binary is attempting to write the file to disk since we don't use it here.
Edit: Quick variation on the above, using one of the lines from your post a few up this thread. Create a new variable with the echo line that swaps out spaces for escaped spaces, like this-
DiskName=`echo "$driveName" | sed 's/ / /g'
savscan=`/usr/bin/sweep /Volumes/$DiskName | grep ">>> Virus" | cut -d"'" -f3 | cut -c 16- | sed 's/ / /g'`
touch "$savscan"
That should, in effect, be passing /Volumes/RALLY2 64GB to the command, which hopefully won't trip it up. Didn't test that at all, so I could be talking out of my rear. Hopefully it works though!
  • February 26, 2013
Oy. Amateurs. Throw it through awk
diskutil list | grep "Macintosh HD" | awk '{print $3 " " $4}' | awk '{printf(""%s"
", $0);}'
Replace "Macintosh HD" with your "RALLY2" (or whatevs). Encapsulating your path with quotes works the same as escaping the spaces.
  • February 26, 2013
no joy im afraid Mike
# Get the disk name of the removable Media
for disk in $(diskutil list | awk '/disk[1-9]s/{ print $NF }' | grep -v /dev); do
if [[ $(diskutil info $disk | awk '/Protocol/{ print $2 }' | egrep "USB|FireWire|SATA") != "" ]]; then
echo "Device $disk is a removable disk"
driveName=`diskutil info $disk | awk -F"/" '/Mount Point/{ print $NF }'`
done
savscan=`/usr/bin/sweep "/Volumes/$DiskName" | grep ">>> Virus" | cut -d"'" -f3 | cut -c 16- | sed 's/ /\\ /g'`
touch "$savscan"
i will look at that Jared, i just need to quit the computer for a while before my wife hits me again.
  • February 26, 2013
haha tell her to start helping then :)
  • February 26, 2013
Unfortunately doesnt work in my script Jared
  • February 26, 2013
Can you clarify exactly what it is you're looking to do here? I'm just not sure what the ultimate goal is. Perhaps there's a better way to handle this?
'Cause I don't see why quoting the disk name variable doesn't work. Quoting items with spaces is standard practice, so something wonky is going on if its not working for you.
For example, the following works fine for me-
        diskName=$(diskutil info $disk | awk -F: '/Mount Point/{print $NF}' | sed 's/^[ 	]*//' )
        echo "Hello World" > "$diskName/myfile.txt"
done
It creates a new file at the root of an attached USB drive called "myfile.txt" with the contents of "Hello World"
I tested it with a USB drive named "32 GB thumb drive", so lots of spaces and it had no issue writing the txt file to the drive. Your /usr/bin/sweep command must be doing something different than the norm if it gets tripped up on touching the file to the disk.
  • February 26, 2013
The ultimate is to automatically scan external media as soon as it gets plugged in, to then go and touch the virus if it exists to cause the Quarantine Manager to display the warning to the user.
I did the same thing by writing it to a text file and it seemed ok.
I then tried to used the text file in a variable but still didnt work. I think your right with that sweep command doing something different.
Thanks for your help i will keep playing around with it.
  • February 26, 2013
strange thing is though
/usr/bin/sweep "$diskName" | grep ">>> Virus" | cut -d"'" -f3 | cut -c 16- | sed 's/ /\\ /g'
done
comes back with what i want
but what ever i do i cant get it in a variable to touch it.
  • February 27, 2013
Why can't you jus use a redirect instead of trying to touch the file as a separate step? You're already pulling the info you want with the grep ">>> Virus" part. Just try to redirect the output into the file on the same line with > "$diskName/somefilename"
  • February 27, 2013
bikeshed threads like this are fun. *
take a look at using a launchdaemon with a watchpath to do things on volume mount.
or crankd might fit the bill. it uses system events to trigger behaviors. here's a detailed intro:
http://glarizza.com/using-crankd-to-react-to-network-events
or keep writing fragile shell scripts with positional parameters that will break easily.
do be sure to drop some change in your technical debt relief fund when you're done, though.
* i'm really crying here.
  • February 27, 2013
@mm2270
i am trying to touch the file to activate the Sophos Quanarantine manager which will then show the user the message and eject the removable media
https://jamfnation.jamfsoftware.com/viewProductFile.html?id=115&fid=634
the sweep command just flags to the shell with >>> Virus where as the gui app says "Threat" in the Sophos Log.
The point is that the sweep command is pants and thanks for your help guys but please refrain from making comments like Oi Amateurs etc Jared
  • February 27, 2013
@rockpapergoat
plan to ... but need a working script before i do the next phase which is launch daemon
  • February 27, 2013
not sure why it didnt work yesterday but it does today
i noticed on my usb drive i had another file called the same thing
In terminal is showed as com.eicar.txt^M. After deleting it all is ok
##########################################   HISTORY ##################################################
#  Created by Tim Kimpton        #
#  27/2/2013        #
#  Version 1.5        #
# This is used with a launch daemon to run the script every time a volume is mounted                  #
# This script will search if there is removable media and will automatically scan the media           #
# If there is a virus the system tries to "touch the file" which activate the SAV Quarantine Manager  #
# Use the Sophos Anti-Virus sweep command to scan the removable media
sav=`/usr/bin/sweep "$diskName" | grep ">>> Virus" | cut -d"'" -f3 | cut -c 16- | sed 's/ /\\ /g'`
# Touch the file to Triggeer the Sophos Quarantine Manager
touch "$sav"
done
  • March 23, 2013
Hello,
I'm having an issue using the "diskutil secureErase freespace 3/ Volume/name-of-drive" command.
The name of my hard drive is Macintosh HD but the command keeps saying can't find "HD". If I don't put a space, it'll come back with can't find "MacintoshHD"
Any ideas on how to get this to work?
