We have posted an update to the NetSUS Appliance OVA that is now available for download at: https://jamfnation.jamfsoftware.com/viewProduct.html?id=180
The following updates and fixes are included in the update:
- Increased the NetSUS Appliance default disk size to 200G
- Fixed an issue with scheduled syncing not completing
- Added Australian time zones (thanks to rickgmac)
- Added Root Branch support for the Mountain Lion Software Update catalog
- Updated reposado
- Fixed NetBooting across subnets when holding the N key (the NetBoot image may still not show in the System Preferences Startup pane across subnets depending on network configuration)
For those who already have the NetSUS Appliance deployed and would like the NetBoot fix we have posted the binary for download at:
https://github.com/downloads/jamf/NetSUS/dhcpd
After downloading the file you can stop the NetBoot service, put the new dhcpd file in place, and start dhcpd again.
- sudo killall dhcpd
- copy the new binary to /usr/local/sbin/
- sudo /usr/local/sbin/dhcpd
Any other update you would like to implement in an existing environment can be done by visiting https://github.com/jamf/NetSUS/commits/master to see the code changes.
We would like your feedback on the usefulness of the appliance and what components you are able to take advantage of. We look forward to the continued participation and community support that has taken place around the NetSUS Appliance.
