New MDM command for managed applications (Big Sur)
  • January 14, 2021
  • 0 replies
  • 3 views
Hello,
Do you know if the new MDM command for managed applications with big Sur is implemented in Jamf or if it will be in future releases?
App management
App management in previous macOS versions is a far cry from the experience in iOS. For instance, an app could be installed via MDM in macOS, however there is no mechanism for marking that app as managed or for uninstalling it. As of macOS 11 Big Sur, the app management experience is much more similar to what it is in iOS today. What’s new?
Apps can be removed by MDM commands or upon enrollment
iOS-style managed app configuration and feedback are supported
Device enrollments can convert an unmanaged app to managed
Thank you,
