I saw this recently too.
Attach a apple keyboard then try.
Regards,
Ben Toms
When it netboots, it finds the new image we have created, but what opens is the NetInstall LaunchPad. In the past, it went directly to the Image Utility. I can live with clicking a button, at least for now, but the button doesn't launch the Casper Imaging. Clicking on apple-C doesn't work either. I have a splash screen of the casper suite logo, and the window for the Launchpad. There is no dock, there is no app folder.
Melinda Garrelts
LHS Technology
(308) 324-4691 x1271
(308)324-1271 direct
(308) 746-2427 cell
Sorry but I just assumed you were using a standard netboot with casper imaging loading at startup.
Because that's what we do! & we had a similar issue when netbooting the latest released imacs with no kb attached after holding n to netboot.
Regards,
Ben Toms
When you created the new NetBoot image, did you do that on the new machines?
On Fri, Feb 11, 2011 at 11:43 AM, Melinda Garrelts <melinda.garrelts at esu10.org> wrote:
I mean the entire process, or did you target disc the new machine onto an
old machine to snapshot with Composer and create the NBI?
My experience has been that with new hardware you have to do everything on
the new hardware. You cannot Target Disc onto an older piece to snapshot or
create the NBI.
HTH
Steve Wood
Director of IT
swood at integer.com
T 214.758.6813 | F 214.758.6901 | C 940.312.2475
Hey Melinda,
I assume you've already imported these new iMacs into the database? Under
Autorun, is 'Automatically Image this Computer the next time Casper Imaging
is launched' checked for these machines?
Christopher Kemp
CNN-BEST Central Engineering
Hi Melinda,
Try this link, I've used it in the past when setting up casper imaging to run automatically.
http://jamfsoftware.com/kb/article.php?id=236
If you don't want to be prompted for what image to use, you'll need to fill in the autorun fields for the computers in the inventory tab of the jss, or fill in the prestage so the image is auto selected.
Hope this helps,
Lisa.
Lisa Davies
ICT Client Services Manager
Saint Ignatius' College, Riverview
Phone: 02 9882 8413
Mobile: 0417 005 735
Thank you everyone for your suggestions. Dusty was right, of course, being support for JAMF. Earlier in the week we upgraded the Casper server, being far late in doing so. The imaging client was not put correctly in place. In addition, I had one too many checkboxes checked somewhere. We managed to get it up and running with the help of Eric at JAMF, in time to leave at a normal hour on Friday and no weekend work. Thanks again everyone for the help!
Melinda
