No Remote Management prompt after clean OS install
  • May 21, 2020
  • 26 replies
  • 1146 views
Show first post
  • August 4, 2022
has anyone been to get this work on an M1 running Monterey? Even at the language selection screen, when Terminal is opened the user is _mbsetupuser, not root.
Command worked for me except for an M1 MacBook Pro running macOS 12.5 I had to execute that command AFTER going through Setup Assistant. Then I used the System Preference option to "Erase all Content and Settings" and then went through Setup Assistant again. This time around the Remote Management screen appeared in Setup Assistant. When the "profiles renew" command actually works on a logged in mac, you should see a Notification Center pop-out from the right side of the screen informing you to enroll the computer. If you don't see this notice in Notification Center then most likely something else is wrong with the computer's ASM/ABM related settings - whether that be on your or Apple's end of things.
