Not able to download from JDS, possible certificate issue ?
  • February 26, 2016
  • 8 replies
  • 72 views
Hi all,
I'm flumoxed on this one!
Yesterday i noticed that any policies that download pkgs or dmgs from the JDS were failing, (Self Service and recurring), policies that do not download are successful. I've tested on 4 different Macs at different sites and all get the same errors.
There are a few threads saying that spaces in the file names can cause a similar issue and it was fixed in 9.72, we're using 9.72 and these have been working 100% for the last few years up till yesterday.
Looking at the JSS logs i get 40+ lines of
Downloading https://fqdn/CasperShare/Software Update.pkg... Error: Could not connect to the HTTP server to download Software Update.pkg
if i trigger the same policy from Terminal the error is this
Downloading https://fqdn/CasperShare/Software Update.pkg... 2016-02-26 10:22:09.563 jamf[95462:5647] NSURLConnection/CFURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9814) Error: Could not connect to the HTTP server to download Software Update.pkg
If copy/paste the package url into Safari it downloads with no issues at all
I've also noticed that now when i open Casper Admin it gives me a certificate error, showing that the cert has expired, i'm assuming the download issue could be related to this ?
Checking on the JSS the Tomcat cert is definitely valid, i know we installed it in December.
If i view the certificate by right clicking on the JSS URL in Safari it also shows the same valid certificate.
I'm not sure where this old certificate is being picked up from ? i've spoken to the network team and been assured that nothing has changed...
This is the message when opening Casper Admin
Any ideas what may be causing this or where else i should start digging ?
Thanks,
Andy
Best answer by stevewood
@May did you check the cert on the JDS too? I'll bet the issue is with the cert there and not the one on the JSS.
You could try running the JDS setup utility again. I believe during the setup process the JDS will re-certify itself with the JSS. That is, after all, where the JDS gets its cert, unless you are using a public cert on the JDS.
Actually, you may be able to just use the enroll verb with jamfds:
jamfds enroll --prompt
stevewood
Forum|alt.badge.img+38
  • February 26, 2016
  • February 26, 2016
Thanks @stevewood
I just re-ran the JDS installer, restarted Tomcat but it still has the same issue, do you know how i can view the JDS certificate ? i can't see anything in JSS > JDS Instances.
Does the JDS not use the same certificate as Tomcat ?
Cheers
  • February 26, 2016
I just tried this command from this thread [https://jamfnation.jamfsoftware.com/discussion.html?id=8246](thread)
What do you get if you run 'openssl s_client -connect jss.mycompany.com:8443'?
This is the result
CONNECTED(00000003)
98372:error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure:/SourceCache/OpenSSL098/OpenSSL098-52.8.3/src/ssl/s23_clnt.c:593:
stevewood
  • February 26, 2016
@May what OS is your JDS running on? I'm running on Ubuntu, and I can view the certs in the Certs folder:
/usr/local/jds/certs
By using the following on each .cer file in that folder, I can view the info for the cert:
openssl x509 -inform der -in jss_ca.cer -noout -text
Just change out the .cer file that you want to view. You can find out what cert files are being used by Apache by looking in:
/etc/apache2/sites-enabled/jds.conf
You can also see what SSL Protocols are enabled in here too.
  • February 26, 2016
Thanks @stevewood i found it
It's on OS X, the path is /Library/JDS/certs the one that's expired it's the webserver.cer
just trying to find how that gets installed
  • February 26, 2016
@stevewood it's now working, thanks!
If i'd followed all of your advice i would have got it running quicker!
The jamfds enroll --prompt command worked, it renewed the webserver.cer and downloads from the JDS are now working, interestingly re-installing the JDS did not renew the certificate.
Do you know if this is this something that will need to be run manually each time before that cert expires or should it be automated ?
Thanks again for your help!
Andy
stevewood
  • February 26, 2016
@May glad it worked out for you! I believe that each time you upgrade the JDS to the latest version, the certificate is renewed. However, don't take my word for it, perhaps shoot an email to your TAM and ask them.
Also, I think the cert expiration date is pushed way out there, like 5 years or so, so I'm not certain it should expire anytime soon.
  • February 26, 2016
@stevewood cheers,
the expiry on the cert is a year after using jamfds enroll --prompt to renew it, i'm setting a calendar event ;)!
