Once per enrollment trigger
  • October 19, 2020
  • 12 views
Through our experiences with device enrolment, come cases where devices are erased and re enrolled, but their listing left in the system, it causes issues with triggers.
example, a script if set up to run once per computer, as an enrolment trigger, would not run a second time if the device is erased and re enrolled, as it has been run once already.
Is it possible for a run once per enrolment, rather than computer? So if the device is ever re enrolled, it repeats the policy, instead of skipping it?
1 reply
sdagley
  • October 19, 2020
@Malcolm In the Settings->Global Management->Re-enrollment page on your JSS console enable "Clear policy logs on computers". That will make all run once policies run again when a Mac is re-enrolled.
