One Mac will not connect to JSS or SSL sites post build
  • August 28, 2013
  • 9 replies
  • 43 views
bentoms
Forum|alt.badge.img+35
Hi all,
We have one MacBook that will boot to NetBoot, then re image.
However on first boot the first run script does not run & if you manage to login to it you can only connect to port 80 websites.
Trying to connect to the JSS or any port 443 site results in Safari giving an error that it cannot connect.
Time is correctly set on the mac, so it's not that & the image is & has been used on many other macs.
I'm thinking a hardware issue, but seems odd that it works on a NetBoot.
Thoughts?
Best answer by bentoms
Sorted.. completely over complicated this fix too..
RESET P-RAM worked!
Should've taken a step back & retried the basics.. doh!
  • August 28, 2013
Are you using HTTP to serve the .nbi? What if you change it to only serve over AFP? Can you netboot then?
bentoms
  • August 28, 2013
Hi Andrew,
It does NetBoot & image, just 1st run fails & it has issues connecting to secure sites.
  • August 28, 2013
All secure sites, or just intranet or extranet? If you do a jamf recon -verbose, what do you get?
bentoms
  • August 29, 2013
All.
Last time I ran sudoku JAMF recon -verbose I just got the error "could not connect up the JSS).
bentoms
  • August 29, 2013
RESET P-RAM worked!
  • August 29, 2013
is sudoku a hidden command? ;) gotta love auto-correct!
bentoms
  • August 29, 2013
ha ha awesome!
  • August 29, 2013
Lol!, sudoku, is that like 'cal' except it prints out a sudoku board? That's a good one! @ben, don't correct that. Needs to be preserved for humor's sake! :)
scottb
  • August 29, 2013
Sudoku is #138 of the 137 new features added to Casper Suite 9.
external image link
external image link
