OneDrive Known Folder move workflow
  • September 8, 2022
  • 46 replies
  • 531 views
Hello All,
I was wondering if anyone here has been able to successfully implement OneDrive Known folder move?
We are trying to move user's Desktop and Documents folders to OneDrive, without any user interaction, we have tried to apply these settings using the Applications and Custom settings payload, we can see the CP in System preferences Profiles but nothing changes in Onedrive. Other settings like hide dock icon and open at login are successfully applied with the same CP.
<plist version="1.0">
  <dict>
    <key>KFMBlockOptOut</key>
    <true/>
    <key>KFMOptInWithWizard</key>
    <string>xxxxxxxxx</string>
    <key>KFMSilentOptIn</key>
    <key>HideDockIcon</key>
    <true/>
    <key>OpenAtLogin</key>
    <false/>
  </dict>
</plist>
 Here is the sample of the plist created in the CP.
Thanks,
Best answer by mvu
Yeah, you're right @andrew_nicholas. Curious to know your guys' thoughts on this OneDrive redirect. Do you and your users like the experience?
mvu
Forum|alt.badge.img+20
  • September 9, 2022
What version of OneDrive are you using on the Mac? Once updated to the latest on the current channel, it worked for us.
Is your ORG migrated to M365? When you open OneDrive, did your users need to authenticate?
  • September 9, 2022
Is this in the general release ring yet? The below article makes it sound like it is still only available on the insiders release ring only, so unless that is what you are deploying I'm not sure it will work.
Redirect and move macOS known folders to OneDrive - OneDrive | Microsoft Docs
mvu
  • September 9, 2022
  • September 9, 2022
To be truthful, we don't generally permit the insider release. There are enough problems in the day without adding in 2 hours of troubleshooting only to remember that one user is on an essentially preview version of an app.
mvu
  • September 9, 2022
I don't blame ya
  • September 9, 2022
On the testing machine we are on version 22.166.0807.
Yes we are on O365, when reopen Onedrive it did not ask to authenticate.
  • September 9, 2022
Hi @mvu so you are using an insider version? Is this why it is working for you?
Thanks,
mvu
  • September 9, 2022
Thanks,
Yeah. Can you kick a Mac or two over for testing with this CP?
  • September 11, 2022
Hello @mvu yes it worked, I also had to add a PPPC to give OneDrive Full disk access, and it is working now.
Thanks for your help!
  • October 4, 2022
@sguzman1 Could you please help me out with configuration screenshot ? i tried below settings but nothing worked.
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0">
<dict> <key>KFMSilentOptIn</key>
<string>*******</string>
<key>KFMSilentOptInDesktop</key>
<true/>
<key>KFMSilentOptInDocuments</key>
<true/>
<key>KFMSilentOptInWithNotification</key>
<true/>
</dict>
</plist>
  • October 6, 2022
<true/>
<true/>
<true/>
</dict>
</plist>
Hello,
I had to build 3 different CP:
  • October 13, 2022
Was wondering if this was working smoothly with anyones users. Thinking about implementing this as well for our users, but am quite new to Jamf and quite lost to be honest.
I have managed to get the Full Disk access sorted with PPPC, but am stuck with the whole plist thing. Like where does the <string> data supposed to come from, and how do I inject it to the machines. When I try to add a plist to my CP, it only allows me to add a JSON. Anyone?
  • October 13, 2022
Hello @TheHoff
I used a schema that was posted on another JAMF Nation conversation. I have been trying to find the original post but I can't find it.
How to add it to Jamf? go to configuration profiles> Applications and custom settings> external applications> and then select custom schema and paste the entire text. It will allow you to select every option from a dropdown. I am sorry I can't find the link to the schema, maybe someone out here have it.
  • October 14, 2022
Hello @TheHoff
Thanks for your reply, I will also look around to see if I can find it.
  • October 14, 2022
Hello @TheHoff
I think I have found it: https://pastecode.io/s/34721iky. It came from this post: https://community.jamf.com/t5/jamf-pro/onedrive-configuration-profile/m-p/236630/highlight/true
And I have managed to update my CP. One thing I am not sure of though. I need to fill in the Application domain, and on all examples it states: com.microsoft.OneDriveUpdater. Is there a reason this particular file is targeted? I will test on monday if all works.
piotrr
  • November 9, 2022
It's a staged release. It was in insiders forever but it's slowly coming to Current.
CORRECTING MYSELF HERE: nope, it's still not in Current.
Frustratingly, not even all my own users are staged yet, so some work and some will have to wait. It doesn't hurt to send out the configuration and PPPC beforehand though - if PPPC is in place before OneDrive asks for it, you get that much fewer user interactions. :)
  • November 9, 2022
When i have deployed KFMOptInWithWizard and KFMSilentOptIn only 1st time its working and revoke and tried again not working. Seems to be consistency is missing.  Anyone comes across this issue ?
  • November 16, 2022
I've noticed that on preview channel (22.227.1030), the Backup tab is available on both Intel and Apple Silicon Macs.
However, on the current channel (22.225.1026 ), Backup is available on Intel Macs but not on Apple Silicon ones.
On Intel:
On Apple Silicon M1:
Anyone else noticed the same? Or am I missing something?
  • November 16, 2022
If you push the Configuration Profile to enable this AFTER OneDrive has already been setup and is being used, nothing seems to be happening unless the users quits OneDrive and starts it again.
Is this the expected behavior or is there a way to enable this without having to restart OneDrive?
  • November 17, 2022
On Intel:
Edit to my post above
Even on Intel Macs, Backup tab is not consistently available on version 22.225.1026.
I erased an Intel Mac where Backup was available on 22.225 and set it up again. Now I don't see the Backup option anymore even though I am on the same OneDrive version.
Edit 2:
On my M1 Mac, Backup tab all of a sudden appeared and my OneDrive files appeared on the Desktop without any action from my part, and with OneDrive still being on version 22.225.
Honestly, I am totally lost...
  • November 17, 2022
Edit 2:
Same here, I gave up for now and will have another look after the holidays. It is behaving way to erratic for us to roll out any time soon.
markdmatthews
  • January 12, 2023
It appears to be expected behavior for existing installs that you need to quit and re-open OneDrive per https://learn.microsoft.com/en-us/sharepoint/deploy-and-configure-on-macos#kfmsilentoptin
markdmatthews
  • January 12, 2023
I have had zero luck getting the "Production" ring/tier to work in the com.microsoft.OneDriveUpdater.plist
Deferred and Insiders work as expected:
<dict>
<key>EnableFasterRingUpdate</key>
<integer>0</integer>
    <key>Tier</key>
<string>Production</string>
</dict>
</plist>
  • January 13, 2023
Thanks @markdmatthews. I overlooked the part about restarting OneDrive for the settings to be picked up. I also had Microsoft support confirm that.
  • January 13, 2023
Edit 2:
Edit:
I had some clarification regarding the availability of this feature on a client computer after additional test s and a ticket opened with MS. The OneDrive version needs to be on 22.217.1016 and it needs to be on the Production or Insider ring. If OneDrive is on the Deferred ring, even if it is on 22.217 or higher the Backup tab will not be visible.
The only problem we still have is that MS cannot say how long it will take for the Backup tab to be available once you switch from Deferred to Production ring, and they cannot 100% confirm that all clients on Production ring will have this feature available as it is still "rolling out". We escalated this with MS and asked them to provide us with a reliable way of knowing which OneDrive client has this feature available.
