osascript variable
  • August 13, 2014
  • 21 views
Okay I am trying what I thought would not be difficult. I see many articles showing how to use shell variable in osascript what I want is the opposite. I want to move a osascript variable out to a shell script.
So lets say I have this.
osascript<<END display dialog "Are you ready to begin the installer" buttons {"Yes", "No"} set the answer to the button returned of the result
END
How do I get answer out of the osascript into my shell. I have tried the following
Result=$(/usr/bin/osascript -e 'display dialog "Are you ready to begin the installer" buttons {"Yes", "No"}')
echo “${Results}”
what is echoed back is ""
The assistance of the community is appreciated.
  • August 13, 2014
Not sure about osascript, but you can try using cocoadialog with the "yesno-msgbox" option.
  • August 13, 2014
Result=$(/usr/bin/osascript<<END
activate
set the answer to the button returned of (display dialog "Are you ready to begin the installer" buttons {"Yes", "No"})
end tell
END)
echo "The button clicked was: $Result"
bentoms
Forum|alt.badge.img+35
  • August 13, 2014
@ifbell, your echoing out the $Results variable.. But are setting the $Result variable.
So that little "s" may have been it.
