Outlook 2016 autoconfigure
  • August 13, 2015
  • 220 replies
  • 912 views
Show first post
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • January 26, 2019
@rqomsiya, the AppleScript for Outlook setup was designed for use with on-prem Exchange. It doesn't require Macs be bound to Active Directory but that does help with the lookup of user information.
  • March 7, 2019
@talkingmoose
We have tried a number of times to be able to do simple Outlook/Office 365 registration & setup but had no luck, its something we really want to crack.
Our issue is we authenticate to O365 with a different login to our email address
For example to login and activate O365 I'd use
mg1344@mycompany.net but my email address is griffinm@mycompnay.com
What we find is the outgoing email address is set to mg1344@mycompany.net and not griffinm@mycompnay.com even with the keys in Outlook this still fails to work
defaults write com.microsoft.Outlook OfficeActivationEmailAddress -string "mg1344@mycompany.net" defaults write com.microsoft.Outlook DefaultEmailAddressOrDomain -string "griffinm@mycompnay.com"
What it does is throw up the MS sign inbox with the griffinm@mycompnay.com which then fails as it needs mg1344@mycompany.net
I have had a number of emails back and forth with Jeff Kalvass on this but a fix does not see to be forthcoming from MS so perhaps its back to AppleScript to do this?
talkingmoose
  • Community Manager
  • March 7, 2019
@MatG, Jeff would be THE person who would know best about this feature. Has he indicated the feature got broken?
The only conditions you need in addition to the two you have are to ensure the OfficeAutoSignIn key in com.microsoft.office (note the different domain plist name) is set to TRUE and that you're running Office version 16.19 (released last November) or later.
  • March 7, 2019
It just fails to work as advertised, it seems to take the DefaultEmailAddressOrDomain item as your MS login so I on Outlook activation it then adds the outgoing email to this box when it should be login ID, (I've blanked it out as that is my real email)
I can forward the email trail if you want,, it goes back months now.
talkingmoose
  • Community Manager
  • March 7, 2019
@MatG, instead of the email thread, can you post screenshots of your configuration profiles? In particular, screenshots of the Custom Settings payloads for both com.microsoft.autoupdate2 and com.microsoft.office.
Also, review the profile on your test Mac under Apple menu > System Preferences > Profiles. Do the addresses there look correct? In other words, is Jamf's configuration profile correct? If not, then Outlook won't be correct.
  • March 11, 2019
Hi all,
Does anyone else had this problem:
Offline Address Book is not loading correctly. This folder stays empty: “~/Library/Group Containers/UBF…Office/Outlook/Outlook 15 Profiles/Main Profile/Caches/[Numbers]/Download/”
BUT: You are able to search the Directory / LDAP (Check Names and Address Book)
The reason we found out this is not working was because we were not able to add a Presenter to a Skype Meeting when planing the meeting. Error Message was "Cannot add presenter - Attendees that are not in your company cannot be assigned the presenter role"
Error Message in "~/Library/Containers/com.microsoft.Outlook/Data/Library/Caches/Microsoft/uls/com.microsoft.outlook/logs" is "Exchange account has not manifest URL. Nothing to do." (After :"OAB: Checking to see if we need to update OAB."
If i create a new profile via profile manager and add the Exchange account by hand it is working.
Would be interesting if somebody already had this problem and solved it.
Information:
- Macs bound to AD
- User are using mobile accounts with AD accounts
Thanks all
BR
Daniel
  • March 17, 2019
@MatG The issue you are seeing appears to be with how Outlook is handling the auth. We have the same issue and have opened a Premier case with Microsoft.
  • March 19, 2019
@ MacSysAdmin
Correct we cant seem to fix it.
Let me know if you find out more.
  • May 31, 2019
@talkingmoose Does Outlook Setup 5 run once for every user? Or it only really run once period? Lets say I have a shared iMac thats being used by multiple staff, I want the Outlook Auto Setup to run once for the subsequent users. I asked because I see in postinstall script that it deletes the script when its done.
Edit: NVM, it only deletes the temp profiles.
talkingmoose
  • Community Manager
  • May 31, 2019
@Eigger, it's written in two steps:
  1. At every login, verifies whether Outlook has been configured at all (Exchange account or otherwise). If it verifies it has been configured, then the script halts and does nothing further.
  2. If at login the script determines Outlook has never been configured, it puts the pieces in place to configure Outlook the first time the app is launched. Once configured, it removes those pieces to prevent any more setups.
Hope that clears things.
talkingmoose
  • Community Manager
  • May 31, 2019
@MatG, making sure you see this:
Hi folks!
After working with another customer, I found my instructions in the blog post contained some wrong information that is probably the cause of the problems you're discussing here.
Specifically, I had written that all key/value pairs get added to the com.microsoft.office domain. That's wrong. Only two are for that domain and the third is actually for the com.microsoft.Outlook domain.
We've updated the blog post with the correct information and some additional information and screen shots around using an Extension Attribute to pull in additional information such as a User Principal Name.
Help users activate Microsoft Office 365 and configure Outlook in one click
Apologies for all the confusion! I know it can be frustrating to discover you followed all the steps correctly, but the steps were wrong.
  • January 20, 2020
This seems to have stopped working in Catalina??
  • June 4, 2020
Hi @talkingmoose,
Your Autoconfig is great up to Mojave, do you have plans to adapt it for Catalina as well? That would be so awesome :)
I'm getting this error in Catalina (10.15.5)
Thank you for all your scripts, applications, documents and so much more.
BR
Daniel
talkingmoose
  • Community Manager
  • June 4, 2020
@dpratl, I haven't tested my script on Catalina.
The error code you've shown is something for Jamf, and I don't recall adding anything specifically for Jamf. Have you modified it in any way or doing something different than the instructions in the wiki? I've had to learn a few tricks to make things work on Catalina. Just need to know where to look. (Look for a log file too in ~/Library/Logs for the user.
I have tested scripting in the new Outlook that currently in Insider Fast and that appears to be all kinds of broken in many ways. What version of Outlook are you testing? Also, if you can in any way move to Office 365 to take advantage of the configuration profile settings, that would be ideal.
rqomsiya
  • June 4, 2020
Hi @dpratl and @talkingmoose: I seem to have it working in Catalina running 16.37. Ping me on slack (@macm). Curious as to why its not working for you. We are currently using on-prem exchange so the script is super helpful for our techs.
talkingmoose
  • Community Manager
  • June 4, 2020
Thank you, @rqomsiya! If you kept track of any specific changes you made to the script for it to work on Catalina, I'm happy to update my repo.
rqomsiya
  • June 4, 2020
@dpratl : can you post the apple script you're using? I don't remember any major tweaks, but i'm happy to diff the one I have against your copy.
  • June 5, 2020
@rqomsiya and @talkingmoose:
It was my fault, I'm sorry. The Volume License Serializer was not working anymore, because of that Office had no license and the script failed.
After a re-installation of the MacBook with the correct Serializer Office was activated and also the Profile creation worked. I was too fast with my post here, sorry for that. And thank you for your help :)
I also tested it with Office 2019 (>16.16.x) and it was working as expected. You guys do awesome work.
Have a great weekend
BR
Daniel
talkingmoose
  • Community Manager
  • June 5, 2020
@dpratl, thanks for the follow up. I am wholly amazed the script still works on Catalina. But I'm thrilled too.
talkingmoose
  • Community Manager
  • June 5, 2020
@dpratl, if you're on MacAdmins Slack, could you please lend your voice to this discussion? I'm chatting with the Outlook for Mac PM at Microsoft and we're discussing the future of AppleScript support for the new Outlook that's currently in Insider Fast. In my testing, the scripts completely break and they're trying to determine how to proceed.
https://macadmins.slack.com/archives/C0LAD22PL/p1591374468369200?thread_ts=1591374214.369100&cid=C0LAD22PL
If anyone else is concerned about automated setup for Outlook for Mac with on-premises Exchange servers (not Office 365), feel free to join the discussion!
