Hello,
I noticed a small problem when looking at the JAMF rule execution logs.
Indeed, when we go through a prestage enrollment, during our notify process that calls policies with events name, however it happens that our software reinstallation policies, which works with smarts groups, comes before our policies called during our notify process.
Our check-in is configured on 15 minutes, it happens that depending on the connection the notify process it can last more than 15 minutes, so necessarily the reinstall policies is launched before the end of Notify because for him the software is still not installed => which causes the problem of overlapping rule (notify policies + reinstall policies).
What's the best way to fix this?
Thank you!
Be the first to reply!
