I want to package my com.apple.SoftwareUpdate.plist and have it installed on other macs.
the plist i want packaged will have Automatically check for updates. AND install system data files and security updates CHECKED !!
I DO NOT WANT Download newly available updates in the background CHECKED. !!!
I am going to use that PACKAGES application to package up the .plist and install it in the /Library/Preferences. location. Will this overwrite the .plist that is currently there?
for 10.10. 10.11. and 10.12 systems
