Package could not be mounted - No mountable file system
  • January 12, 2018
  • 5 replies
  • 40 views
boberito
Forum|alt.badge.img+22
I'm pushing out the installer for High Sierra with a policy. It's in a DMG to later be executed with startosinstall from Self Service.
Anyway I'm getting this error on a handful of machines and re-occuring over and over on some of the machines it's pushed to.
Downloading https://MYJAMFSERVER/Packages/Install%20macOS%20High%20Sierra.dmg... Verifying DMG... Verifying package integrity... Installing Install macOS High Sierra.dmg... Error: The package "Install macOS High Sierra.dmg" could not be mounted (no mountable file systems).
A lot of machines received it no problem, but a handful haven't with this error reoccurring. I thought maybe the connection was getting interrupted but it doesn't seem like that, if I SSH into a machine and execute the policy from the terminal I'll still see the error and never get booted from the SSH session. I don't believe I've ever seen this with other policies and packages before.
Best answer by boberito
You might be onto something. It looks like it's failing on machines that are 10.12.3 or lower. It's cached perfectly on 10.12.4 and up machines. Instead of re-pushing the package I think I'll just force these machines to update.
  • January 12, 2018
@boberito
From what I have seen and tested this happens when you create packages on a APFS system like a HighSierra machine - and then deploy them to a computer that is not APFS or highSierra.
  • January 12, 2018
I'll second that, was driving me crazy until I though to recreate the package in question on a non APFS/High Sierra machine.
The problem immediately went away.
boberito
  • January 12, 2018
boberito
  • January 14, 2018
Confirmed it. I updated a machine to 10.12.6 and it worked perfectly. So ya, something in 10.12.4 makes it work.
chris_kemp
Forum|alt.badge.img+20
  • January 14, 2018
10.12.4 was when they introduced APFS capabilities.
