Packaging Maya 2025
  • July 8, 2024
  • 29 replies
  • 1028 views
LaszloTarnai
I would like to create a deployment for Maya 2025 based on the topic for 2024:
https://community.jamf.com/t5/jamf-pro/packaging-autodesk-maya-2024-with-redundant-license-servers/m-p/298743
I've found a .app installer in the Contents of the installer:
/tmp/maya2025/AdskIdentityManager/AdskIdentityManager-Installer.app
This app opens an installation wizard. How can I execute this (after the PKG installs) in silent mode?
Thank you.
Best answer by LaszloTarnai
My solution is the following (only the installation part):
pkgpath="/tmp/InstallMaya2025.app" installMaya() { for PKG in $(find "$pkgpath" -name "*.pkg"); do echo "Installing $PKG" installer -pkg ${PKG} -target / done echo "Maya 2025 installed" sleep 3 # Run the AdskIdentityManager-Installer.app in silent mode "$pkgpath"/Contents/Helper/Packages/AdskIdentityManager/AdskIdentityManager-Installer.app/Contents/MacOS/installbuilder.sh --mode unattended echo "Autodesk Identity Manager installed" }
RaGL
  • July 8, 2024
In general to execute an installer silently you can use:
installer -pkg /tmp/maya2025/AdskIdentityManager/AdskIdentityManager-Installer.app -target /
LaszloTarnai
  • July 8, 2024
Unfortunately no luck with this command.
installer: Error - the package path specified was invalid: '/tmp/InstallMaya2025.app/Contents/Helper/Packages/AdskIdentityManager/AdskIdentityManager-Installer.app'.
  • July 8, 2024
I believe the installer commands the XCLI version of the installer.app GUI and as such will only work with .pkg type files; if what you are attempting to install is a .app it could in theory, be opened with the CLI vi the 'open' command, but then you'd still have to deal with its GUI prompts.
Been awhile since I felt with Maya, but if the installer doesn't come packaged as a .pkg, run the installer, and then use composer to package Maya as a .pkg, then the JAMF native options or the above command would work.
LaszloTarnai
  • July 9, 2024
As I saw that, AdskIdentityManager-Installer.app writes files inside Maya.app, so maybe it's not the best approach to create a PKG from my installation.
Is it a possibility to run "Install Maya 2025.app" in silent mode via Jamf?
LaszloTarnai
  • July 9, 2024
I guess I've found a solution, but I'm gonna test via Jamf:
sudo /Volumes/Install\\ Maya\\ 2025/Install\\ Maya\\ 2025.app/Contents/Helper/Packages/AdskIdentityManager/AdskIdentityManager-Installer.app/Contents/MacOS/installbuilder.sh --mode unattended
cgeorge
  • July 9, 2024
AdskIdentityManager doesn't install the full Maya software, only a component. I'm working to update the 2024 script for 2025 today.
cgeorge
  • July 9, 2024
this has successfully tested for me:
#!/bin/sh #Application Info (For each AutoDesk app, change the app/year/pKey/package) app="Maya" year="2025" pKey="#####" #Location where the application file is going to sit (REMOVE THE SPACES IN NAME) pkgpath="/private/tmp/InstallMaya2025.app" #For Redundant Servers, have a space between them rather than a comma ex: networkServer="IPaddress1 IPaddress2 IPaddress3" networkServer="##.##.##.###" #Identify where the license file will be generated at licPath="/Library/Application Support/Autodesk/AdskLicensingService/${pKey}_${year}.0.0.F" licFile="licpath.lic" #All packages that exist within the Package Contents, conduct install runInstaller () { for PKG in $(find "$pkgpath" -name "*.pkg"); do echo "Installing $PKG" installer -pkg ${PKG} -target / done } #Creates and appends servers identified into 'new' license file, 'for each' server that exists, write to file createLicenseFile () { /bin/mkdir -p "${licPath}" /usr/bin/touch "${licPath}/${licFile}" for server in ${networkServer}; do echo "Accounting for server $server" /bin/echo "SERVER ${server} 000000000000" >> "${licPath}/${licFile}" done /bin/echo "USE_SERVER" >> "${licPath}/${licFile}" /bin/echo "_NETWORK" >> "${licPath}/${licFile}" } #Append the license servers to the products installed, 'ls' is list servers based on @IP,@IP... distinction LicenseHelper () { ### based off Onkstons's terrific work (I think they we're the first?) but simplified for 2023. ### see also, addl details at the end of script for alternative 'legit' licensing method. licPath="/Library/Application Support/Autodesk/AdskLicensingService/${pKey}_${year}.0.0.F" /bin/mkdir -p "${licPath}" /usr/bin/touch "${licPath}/licpath.lic" /bin/echo "SERVER ${networkServer} 000000000000" > "${licPath}/licpath.lic" /bin/echo "USE_SERVER" >> "${licPath}/licpath.lic" /Library/Application\\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper change --pk "${pKey}" --pv "${year}.0.0.F" --lm NETWORK --ls "${networkServer}" } #All files leveraged during installation will be cleaned from system package path and temporary files cleanUp () { /bin/rm -rf "{$pkgpath}" } #Run script (1st Pass) echo "Starting 1st Pass" runInstaller createLicenseFile LicenseHelper #Run script (2nd Pass), the licensing portion doesn't always install/engage during first run echo "Starting 2nd Pass" runInstaller LicenseHelper #Cleanup Files echo "Executing Cleanup" cleanUp ################################################# ### Verify license details - not required, but kind of nice to see. /Library/Application\\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper list echo "Autodesk network licensing complete" ##################################################
LaszloTarnai
  • July 10, 2024
jonw
  • July 22, 2024
Hi All,
Here's my solution for installing 2025 (and 2024) versions Autodesk Maya, Mudbox, and AutoCAD with edu network licenses.
    • Uses stock DMG's from Autodesk - no pkg hacking or repacking required!
    • Silently installs apps and licenses - no user interaction required
    • Works at loginwindow for multi-user lab/classroom deployment
    • Tested on both 2024 & 2025 app versions (macOS 13 & 14) AutoCAD, Maya & MudBox
    • Addresses this ODIS update issue - if you're unaware, GO READ THIS NOW, thank me later...
      https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-application-with-bundle-ID-com-autodesk-install-is-running-setugid-which-is-not-allowed-Exiting.html
    • My scripts still needs some error checking, logging etc.  I just wanted to provide the bare bones for what is working really well for me right now (knock on wood).
    • I'm seeing bits and pieces of my older scripts floating around, incorporated into other solutions, etc... this is not that, quite different, and in my opinion, much easier than the ways of past.
    • More details in the script notes - but I tried to make things easy to parse & modify.
    • I hope it helps!
Steps are:
  1. Upload stock install dmg's to Jamf... don't forget the ODIS patch: Darwin.dmg!
  2. Create a policy to cache dmg's to clients
  3. Create a policy to run the script - or add to the cache policy, your call.
#!/bin/zsh ### Install Autodesk Apps and Licenses ### AutoCAD, Maya & MudBox (2025) ### 2025.07.19 -JonW ### Silently installs apps and licenses - no user interaction required ### Uses stock DMG's from Autodesk - no pkg hacking or repacking required! ### Works at loginwindow for multi-user lab/classroom deployment ### Tested on both 2024 & 2025 app versions (macOS 13 & 14) AutoCAD, Maya & MudBox ### A complete uninstall of previous versions is recommended but may not be necessary, ymmv ### Script could use some error checking, logging and fine tuning ... will get that on a slower day ### Ensure stock Autodesk install DMG's are set to CACHE (not INSTALL) via Jamf policy ### Update script variables in each of the 'app blocks' below ### - fyi check PIT (app config file) paths every year! Will need to perform a temporary manual installation to determine if they change or not. ### - fyi more info on license options: /Library/Application\\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --help ### !!! Important !!! ### !!! 2025 Silent install patch info - aka ODIS update !!! ### https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-application-with-bundle-ID-com-autodesk-install-is-running-setugid-which-is-not-allowed-Exiting.html ### I had to tweak the ODIS patcher... It sort of defeats the purpose if the patcher itself doesn't work silently! C'mon Autodesk! ### (at least as of 2024.07.19) tweaks: ### - the /Volumes/Darwin/ path in the article is wrong! For me it's loading as: /Volumes/Macintosh\\ HD\\ 1/ ### - this thing will throw Apple quarantine issues - resolving with xattr (i.e. just ignore the article instructions!) ### - the article makes no mention of the patch .sh script flag --mode unattended !!! ### I found it by digging around in the patch files! But hey, at least it's there right? It's always something isn't it!? ############################################################################################## ### Function installApp () { if [[ -e "${dmg}" ]]; then ### Mount dmg, install silently & unmount echo "installing: ${dmg}" hdiutil attach -nobrowse "${dmg}" "${Setup}" --silent hdiutil detach "${Volume}" else echo "cannot locate dmg for: ${dmg}" echo "skipping install attempt" fi } ############################################################################################## ### Function applyLicense () { if [[ -e "${ConfigFile}" ]]; then ### Apply License ### details: /Library/Application\\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --help /Library/Application\\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --pk "${ProductKey}" --pv "${ProductVersionYear}${productVersion}" --cf ${ConfigFile} --lm NETWORK --ls "${networkLicenseServer}" else echo "license attempt failed, for product: ${ProductKey}" echo ".pit config file could not be located" fi } ############################################################################################## ### Function silentInstallPatchODIS () { ### See notes above!! ### Tweaks as of 2025.07.19 - be aware Autodesk could change this at any time! ### This is the ODIS Update dmg hdiutil attach -nobrowse /private/tmp/Darwin.dmg ### Let's move contents out of DMG to a tmp dir mkdir -p /tmp/Autodesk_ODIS_Update_Contents cp -R /Volumes/Macintosh\\ HD\\ 1/* /tmp/Autodesk_ODIS_Update_Contents ### Detach volume hdiutil detach /Volumes/Macintosh\\ HD\\ 1 ### fix quarantine issues - probably just need 2nd command, but let's go wild xattr -rd com.apple.quarantine /tmp/Autodesk_ODIS_Update_Contents xattr -rc /tmp/Autodesk_ODIS_Update_Contents ### run patch script - note, found ref to the --mode unattended flag buried in one of the supporting files, not in article?!? /tmp/Autodesk_ODIS_Update_Contents/AdODIS-installer.app/Contents/MacOS/installbuilder.sh --mode unattended } ############################################################################################## ############################################################################################## ### Begin script ############################################################################################## ############################################################################################## ############################################################# ### Move cached DMG's from Jamf staging area to /private/tmp/ mv /Library/Application\\ Support/JAMF/Waiting\\ Room/Autodesk* /private/tmp mv /Library/Application\\ Support/JAMF/Waiting\\ Room/Darwin* /private/tmp ############################################ ### Apply ODIS update - aka Silent install patch silentInstallPatchODIS ############################## ### AutoCAD - install & license networkLicenseServer="your.license.server.com" ProductKey="777Q1" ### note, ProductKey may differ! productVersion=".0.0.F" ### note, ProductVersion may differ! ProductVersionYear="2025" dmg=/private/tmp/Autodesk_AutoCAD_2025_macOS.dmg ### full path to install dmg in /tmp Volume=/Volumes/Installer ### attached dmg volume Setup=/Volumes/Installer/Install\\ Autodesk\\ AutoCAD\\ 2025\\ for\\ Mac.app/Contents/Helper/Setup.app/Contents/MacOS/Setup ### full path of setup app ConfigFile=/Library/Application\\ Support/Autodesk/ADLM/.config/ProductInformation.pit ### full path of installed config file - used by license function installApp applyLicense ############################## ### Maya - install & license networkLicenseServer="your.license.server.com" ProductKey="657Q1" ### note, ProductKey may differ! productVersion=".0.0.F" ### note, ProductVersion may differ! ProductVersionYear="2025" dmg=/private/tmp/Autodesk_Maya_2025_1_Update_macOS.dmg ### full path to install dmg in /tmp Volume=/Volumes/Install\\ Maya\\ */ ### attached dmg volume Setup=/Volumes/Install\\ Maya\\ 2025/Install\\ Maya\\ 2025.app/Contents/Helper/setup.app/Contents/MacOS/Setup ### full path of setup app ConfigFile=/Library/Application\\ Support/Autodesk/ADLM/PIT/2025/MayaConfig.pit ### full path of installed config file - used by license function installApp applyLicense ############################## ### Mudbox - install & license networkLicenseServer="your.license.server.com" ProductKey="498Q1" ### note, ProductKey may differ! productVersion=".0.0.F" ### note, ProductVersion may differ! ProductVersionYear="2025" dmg=/private/tmp/Autodesk_Mudbox_2025_macOS.dmg ### full path to install dmg in /tmp Volume=/Volumes/Install\\ Mudbox\\ */ ### attached dmg volume Setup=/Volumes/Install\\ Mudbox\\ 2025/Install\\ Mudbox\\ 2025.app/Contents/Helper/setup.app/Contents/MacOS/Setup ### full path of setup app ConfigFile=/Library/Application\\ Support/Autodesk/ADLM/PIT/2025/MudboxConfig.pit ### full path of installed config file - used by license function installApp applyLicense ########################################################################### ### Verify license details for all apps - optional, but nice to see in logs /Library/Application\\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper list echo "-------------------------" echo "Autodesk install complete" echo "-------------------------" ########################################################################### ### Ensure dmg volumes are detached ### Temporary script step, added last minute. Still need to flesh this out hdiutil detach /Volumes/Macintosh\\ HD\\ 1 > /dev/null 2>&1 ### This is the 'Darwin' ODIS Update dmg NOT the system volume hdiutil detach /Volumes/Darwin* > /dev/null 2>&1 hdiutil detach /Volumes/Installer > /dev/null 2>&1 hdiutil detach /Volumes/Install\\ Maya\\ */ > /dev/null 2>&1 hdiutil detach /Volumes/Install\\ Mudbox\\ */ > /dev/null 2>&1 ########################################################################### ### Clean up installers - optional, /private/tmp should auto purge on reboot ### rm -rf /private/tmp/Autodesk* ### rm -rf /private/tmp/Darwin*
  • July 22, 2024
Hi All,
    • I hope it helps!
Steps are:
I had just discovered the issue with the AdODIS patch and was trying to incorporate that fix into my own install script and stumbled upon this. Thank you so much for including the "--mode unattended" key in your script. This was the exact piece I was missing.
MCerano
  • August 8, 2024
Hi All,
    • I hope it helps!
Steps are:
Hey @jonw,
A few days ago I had managed to get this whole process working on my end, however now that I've updated the location of our license server I keep getting this error. I suspect that it has to do with the server update, but this same error happened when I changed it back to the original address. Any help would be appreciated!
  1. Executing Policy Install Maya 2025
  2. Caching package Install Darwin for Maya...
  3. Downloading https://avc.jamfcloud.com/jcds/downloads/Darwin.dmg...
  4. Verifying DMG...
  5. Caching package Install Maya 2025...
  6. Downloading https://avc.jamfcloud.com/jcds/downloads/Autodesk_Maya_2025_macOS.dmg...
  7. Verifying DMG...
  8. Running script Maya 2025 Install...
  9. Script exit code: 1
  10. Script result: expected CRC32 $8C6AF337
    /dev/disk4 GUID_partition_scheme
    /dev/disk4s1 Apple_APFS
    /dev/disk5 EF57347C-0000-11AA-AA11-0030654
    /dev/disk5s1 41504653-0000-11AA-AA11-0030654 /Volumes/Macintosh HD 1
    "disk4" ejected.
    installing: /private/tmp/Autodesk_Maya_2025_macOS.dmg
    expected CRC32 $D5C10959
    /dev/disk4 /Volumes/Install Maya 2025 2
    2024-08-08 09:00:17.735 Setup[28911:318069] The application with bundle ID com.autodesk.install is running setugid(), which is not allowed. Exiting.
    hdiutil: detach failed - No such file or directory
    "feature_id": "ARNOL",
    "def_prod_key": "C0PQ1",
    "def_prod_ver": "2025.0.0.F",
    "sel_prod_key": "C0PQ1",
    "sel_prod_ver": "2025.0.0.F",
    "lic_method": 4,
    "supported_lic_methods": [
    2,
    1,
    4
    "serial_number_sa": "000-00000000",
    "serial_number_nw": "000-00000000",
    "def_prod_code": "ARNOL",
    "sel_prod_code": "ARNOL"
    "feature_id": "MAYA",
    "def_prod_key": "657Q1",
    "sel_prod_key": "657Q1",
    "lic_method": 1,
    2,
    1,
    4
    "lic_servers": [
    "my license server here"
    "def_prod_code": "MAYA",
    "sel_prod_code": "MAYA"
    /Library/Application Support/JAMF/tmp/Maya 2025 Install:150: no matches found: /Volumes/Darwin*
  11. Error running script: return code was 1.
jonw
  • August 8, 2024
Hey @jonw,
  4. Verifying DMG...
  7. Verifying DMG...
    "disk4" ejected.
    "lic_method": 4,
    2,
    1,
    4
    "lic_method": 1,
    2,
    1,
    4
    "lic_servers": [
The error "com.autodesk.install is running setugid(), which is not allowed" is definitely related to the AdODIS patch, but I have no idea of how it plays into this situation. Did you uninstall everything before the re-install attempt? Or at least unload the Autodesk Daemons and remove anything relevant in /Library/Application Support/FLEXnet Publisher/Service (careful other apps may use FLEXnet)?
launchctl bootout system /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist launchctl bootout system /Library/LaunchDaemons/com.autodesk.adskaccessservicehost.plist ### the two Autodesk related directories I currently (yours may differ) rm -rf /Library/Application\\ Support/FLEXnet\\ Publisher/Service/11.16.6 rm -rf /Library/Application\\ Support/FLEXnet\\ Publisher/Service/11.18.3
jonw
  • August 8, 2024
fwiw- you should be able to whip up a new script to just re-run the licensing bits with uninstalling apps.
ianatkinson
  • August 20, 2024
why does the second run call the app installs again, if it's to double check licensing doesn't it just need to run the licensing function?
  • August 20, 2024
I can confirm that Autodesk installations, even when done exactly per their instructions, are unreliable at best. I don't have mine set to repeat the installation, but I do have my policy set to ongoing with a smart group of "Maya installed" as an exclusion.
Then to keep it from installing every 30 minutes (on check-in), I simply set the install policy to run every night.
jonw
  • August 20, 2024
@kacey3 @ianatkinson fwiw - most of the script above posted by @cgeorge is from my older work, but running the app installers a 2nd time in the script is not.  My original script just re-ran the license function for good measure, as is noted in the comment.  Additionally, this script still uses a mashup of old license file hackery techniques alongside official Autodesk workflows, which works but isn't ideal in my opinion.
Also fwiw- my new script/process down thread (dated 2024.07.19) uses official workflows for everything and has been flawless going out to ~200 lab computers for the past two years (including the ODIS curveball they hit us with this year).  Feel free to use any or all of it - my point being that despite the PITA Autodesk can be, I can say for now at least a 100% success rate in deployments with network licensing is obtainable.
ianatkinson
  • August 21, 2024
Thanks I'm going to give your script a go today, I wrestled with this all yesterday afternoon and thought I'd got the licensing working ... pushed the policy and they've all failed :/
This was a lot simpler years ago when all you had was the one file telling it where the flex server was, this local licensing daemon that it seems to run now is what's causing the problems. Grrr!
ianatkinson
  • August 21, 2024
OK having spent a bit more time on this I think my issue was that the local licensing daemon wasn't always running. If it's not running then the file `
/Library/Application Support/Autodesk/AdskLicensingService/AdskLicensingService.data` will not be present and the calls to register the apps fail saying it can't find that file (rather than saying the service is down which would be more useful.
I've knocked up my own script from bits on here and my own stuff and this includes a check on the daemon, if it's not running it has a go at bringing it to life and this seems to be working OK for me. I'll include it below in case it's of use for anyone else.
#!/usr/bin/env zsh function start() { echo echo "=====================================================" echo "| $1" echo "=====================================================" } function uninstall() { # https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall-of-Autodesk-programs-on-a-Mac.html start "Removing old Autodesk Files" rm -rf /Applications/Autodesk rm -rf /Library/Logs/Autodesk rm -rf /Library/Application\\ Support/Autodesk rm -rf /Library/LaunchDaemons/com.autodesk* } function runInstaller() { start "Installing $app" for PKG in $(find "$pkgpath" -name "*.pkg"); do installer -pkg ${PKG} -target / done } function createLicenseFile() { licPath="/Library/Application Support/Autodesk/AdskLicensingService/${pKey}_${year}.0.0.F" licFile="licpath.lic" if [[ ! -f "${licPath}/${licFile}" ]] ; then start "Making license file" /bin/mkdir -p "${licPath}" /usr/bin/touch "${licPath}/${licFile}" for server in ${networkServer}; do echo "Accounting for server $server" /bin/echo "SERVER ${server} 000000000000" >> "${licPath}/${licFile}" done /bin/echo "USE_SERVER" >> "${licPath}/${licFile}" /bin/echo "_NETWORK" >> "${licPath}/${licFile}" fi } function licenseProperly() { start "Licensing $app" kills=0 # make sure daemon is running to accept registration while [[ ! -f "/Library/Application Support/Autodesk/AdskLicensingService/AdskLicensingService.data" ]] ; do echo "...kicking Autodesk licensing daemon" killall -HUP AdskLicensingService ((kills++)) if [[ $kills -gt 5 ]] ; then echo "FATAL: failed to get Autodesk Licensing daemon running" exit 1 fi sleep 3 done # register app "/Library/Application Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper" register \\ --pk "${pKey}" \\ --pv "${year}.0.0.F" \\ --cf "/Library/Application Support/Autodesk/Adlm/PIT/$year/${app}Config.pit" \\ --lm NETWORK \\ --ls "${networkServer}" # check if ! /Library/Application\\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper list | grep -qi $pKey ; then echo "ERROR, $app Licensing Failed" else echo "$app Licensing Complete" fi } # COMMON networkServer="licensing.foo" year="2025" uninstall createLicenseFile # MAYA pkgpath="/tmp/InstallMaya2025.app" pKey="657Q1" app="Maya" runInstaller licenseProperly # MUDBOX pkgpath="/tmp/InstallMudbox2025.app" pKey="498Q1" app="Mudbox" runInstaller licenseProperly # TIDY chown -R root:wheel /Applications/Autodesk chmod -R 755 /Applications/Autodesk # /bin/rm -rf "{$pkgpath}" exit 0
tdenton
  • October 4, 2024
@cgeorge  Are you able to share your 2024 Maya script having many problems with license side of things.
kwoodard
  • June 6, 2025
Hi All,
    • I hope it helps!
Steps are:
Does this script still work with Maya 2026? My understanding is that they no longer use a license server, but named user licenses like Adobe. Anyone get this running?
jonw
  • June 6, 2025
@kwoodard  You just threw me into a panic! 😅  However, I was just now able to download 2026 products and generate 2026 network license server keys valid until June 2026. The official statement is 'As of March 2026, new network and multi-seat licenses for Autodesk software will no longer be offered.'  So it seems we can kick the can down the road for another year.  I haven't had a chance to look into how their 'education institution subscription' option will function/deploy in a lab setting.
I won't have time to test for a few weeks, but I suspect my script from last year for 2024-2025 products (incorrectly dated 2025.07.19) above should work with the appropriate changes for 2026, assuming you're using network keys.  If you do test before I do, I highly suggest a hand install of all apps FIRST to determine if there are any path/spelling changes besides the 'year' in all script variables.
I'll post a 2026 script & details in a few weeks when I have a chance to test.
kwoodard
  • June 6, 2025
Our lead "guy" for Autodesk/Windows software wants us to go with the new edu install. I don't know why he wants to do it now, I assume its to work out any bugs before Fall semester...but it seems like a ton of work. We have to manually add all the students that will have access to the software.
How are you verifying paths to see if there are any changes. I guess literally just looking through Finder, but how do you know you didn't miss something? Why does AutoDesk need to make their installers so ridiculous?!
Another issue I have is that he isn't understanding that I need the optional installs as well, namely Substance... I gave him a link on how to create the Mac package and I get the "deer in the headlights" look when I ask about it. So very frustrating.
I look forward to seeing what you come up with. I have a test machine that I will try your script out on and see how it goes.
kwoodard
  • July 7, 2025
I got a working script created for Autodesk 2026 Maya and AutoCAD. We don’t teach Mudbox… I posted it here in a new thread:
Give it a go and let me know if it works for you!
jonw
  • July 16, 2025
 ​@kwoodard Excellent looking script!  I’m glad you got it worked out!
I’ve added my updated version 2026 w/network license below for anyone still interested because I said I would (successfully deployed Maya. Mud & AC to ~200 lab stations with it), but I think yours is MUCH more thourough.
To use in Jamf policy (should work with 2024, 2025 & 2026):
• edit script variables (DMG names & product/license mostly)
• set DMG installers to CACHE
• run removal script
• run install script
#!/bin/zsh
### Install AutoDesk Maya, MudBox & AutoCAD with network license
### 2025.07.03 - JonW
### Latest update for 2026 app releases
### This script:
### - requires Jamf
### - silently installs apps and network license - no user input required!
### - uses stock DMG's from Autodesk - no pkg hacking or repacking required!
### - works at loginwindow for multi-user lab/classroom deployment
### I highly recommend first removing all prior AutoDesk installations
### In Jamf Policy, ALL DMG's should be set to CACHE (not INSTALL!)
### The variable section below should be the only thing that needs editing
### - The ODIS / AdODIS-installer.app patch may be required for fully silent installs! Info & download here:
### Side Note - I'm seeing the following error in logs from current 2026 installers,
### which appears to be an AutoDesk coding tool issue they need to address (I've reported)
### It does not seem to affect installation/performance and I think can be safely ignored:
### "BullseyeCoverage 9.11.4 error 15: cannot find /test.cov, errno=2 "No such file or directory". COVFILE is not set"
### Variables
### Most frequent changes are to: .DMG installer names & ProductKeys
### Global
networkLicenseServer="your.network.license.server.here"
productVersionYear="2026"
### ODIS Update / AdODIS-installer.app
odisDMG="Darwin.dmg"
odisVolume="Darwin"
### Maya
mayaDMG="Autodesk_Maya_2026_1_Update_ML_macOS.dmg"
mayaProductKey="657R1"
mayaVolume="Install Maya 2026"
mayaSetup=/Volumes/Install\ Maya\ 2026/Install\ Maya\ 2026.app/Contents/Helper/setup.app/Contents/MacOS/Setup
mayaConfigFile=/Library/Application\ Support/Autodesk/Adlm/PIT/2026/MayaConfig.pit
mayaAppPath=/Applications/Autodesk/maya2026/Maya.app
### Mudbox
mudboxDMG="Autodesk_Mudbox_2026_macOS.dmg"
mudboxProductKey="498R1"
mudboxVolume="Install Mudbox 2026"
mudboxSetup=/Volumes/Install\ Mudbox\ 2026/Install\ Mudbox\ 2026.app/Contents/Helper/setup.app/Contents/MacOS/Setup
mudboxConfigFile=/Library/Application\ Support/Autodesk/Adlm/PIT/2026/MudboxConfig.pit
mudboxAppPath=/Applications/Autodesk/Mudbox2026/Mudbox.app
### AutoCAD
autocadDMG="Autodesk_AutoCAD_2026_macOS.dmg"
autocadProductKey="777R1"
autocadVolume="Installer"
autocadSetup=/Volumes/Installer/Install\ Autodesk\ AutoCAD\ 2026\ for\ Mac.app/Contents/Helper/Setup.app/Contents/MacOS/Setup
autocadConfigFile=/Library/Application\ Support/Autodesk/Adlm/.config/ProductInformation.pit
autocadAppPath=/Applications/Autodesk/AutoCAD\ 2026/AutoCAD\ 2026.app
### Begin script
### Move Jamf cached .DMG's from Jamf Waiting Room to /private/tmp/
mv /Library/Application\ Support/JAMF/Waiting\ Room/Autodesk*.dmg* /private/tmp
mv /Library/Application\ Support/JAMF/Waiting\ Room/"${odisDMG}"* /private/tmp
sleep 5
### Install latest ODIS/AdODIS/Darwin patch for Autodesk silent installs from Darwin.dmg
### May not be necessary, but let's do it anyway
echo "installing from: ${odisDMG}"
hdiutil attach -nobrowse /private/tmp/"${odisDMG}"
mkdir -p /private/tmp/Autodesk_ODIS_Update_Contents
cp -R "/Volumes/${odisVolume}"/* /private/tmp/Autodesk_ODIS_Update_Contents
hdiutil detach "/Volumes/${odisVolume}"
xattr -rc /private/tmp/Autodesk_ODIS_Update_Contents
/private/tmp/Autodesk_ODIS_Update_Contents/AdODIS-installer.app/Contents/MacOS/installbuilder.sh --mode unattended
sleep 5
### Install Maya
echo "installing from: ${mayaDMG}"
hdiutil attach -nobrowse /private/tmp/"${mayaDMG}"
"${mayaSetup}" --silent
hdiutil detach "/Volumes/${mayaVolume}"
sleep 5
### Install Mudbox
echo "installing from: ${mudboxDMG}"
hdiutil attach -nobrowse /private/tmp/"${mudboxDMG}"
"${mudboxSetup}" --silent
hdiutil detach "/Volumes/${mudboxVolume}"
sleep 5
### Install AutoCAD
echo "installing from: ${autocadDMG}"
hdiutil attach -nobrowse /private/tmp/"${autocadDMG}"
"${autocadSetup}" --silent
hdiutil detach "/Volumes/${autocadVolume}"
sleep 5
### Clean up ownership - probably not necessary, but it makes me feel better
### Apply Network Licenses
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --pk "${mayaProductKey}" --pv "${productVersionYear}${productVersion}" --cf ${mayaConfigFile} --lm NETWORK --ls "${networkLicenseServer}"
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --pk "${mudboxProductKey}" --pv "${productVersionYear}${productVersion}" --cf ${mudboxConfigFile} --lm NETWORK --ls "${networkLicenseServer}"
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --pk "${autocadProductKey}" --pv "${productVersionYear}${productVersion}" --cf ${autocadConfigFile} --lm NETWORK --ls "${networkLicenseServer}"
### OPTIONAL - Verify app installations & license details
### If an app is missing let's tell Jamf to fail the entire run & try again.
if [[ ! -e $autocadAppPath ]] || [[ ! -e $mayaAppPath ]] || [[ ! -e $mudboxAppPath ]] ; then
echo "ERROR - One or more Autodesk apps didn't install"
### report failure to Jamf!
exit 1
echo "all Autodesk apps installed"
echo ""
echo "verifying network licenses, any return for an app = a good install:"
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper list
echo ""
### Remove Autodesk
### last updated 2025.7.03 - JonW
### CAUTION! /Library/Application\ Support/FLEXnet\ Publisher/Service is shared with ToonBoom (11.18.2), Movie Magic (11.16.4 & 11.8.0) & potentially others.
### Remove with care!
### make sure any install DMG's are ejected
hdiutil detach /Volumes/Darwin > /dev/null 2>&1 #ODIS patch
hdiutil detach /Volumes/Installer > /dev/null 2>&1 #AutoCAD
hdiutil detach /Volumes/Install\ Maya\ 2026 > /dev/null 2>&1 #maya
hdiutil detach /Volumes/Install\ Maya\ 2025 > /dev/null 2>&1 #maya
hdiutil detach /Volumes/Install\ Maya\ 2024 > /dev/null 2>&1 #maya
hdiutil detach /Volumes/Install\ Mudbox\ 2026 > /dev/null 2>&1 #mudbox
hdiutil detach /Volumes/Install\ Mudbox\ 2025 > /dev/null 2>&1 #mudbox
hdiutil detach /Volumes/Install\ Mudbox\ 2024 > /dev/null 2>&1 #mudbox
### Bootout running services
launchctl bootout system /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist > /dev/null 2>&1
launchctl bootout system /Library/LaunchDaemons/com.autodesk.adskaccessservicehost.plist > /dev/null 2>&1
launchctl bootout system /Library/LaunchDaemons/com.autodesk.cer.plist > /dev/null 2>&1
### Remove
### note - some files & dirs below are legacy & may no longer be present
rm -rf /Applications/Allegorithmic
rm -rf /Applications/solidangle
rm -rf /Applications/Substance
rm -rf /Library/Application\ Support/Autodesk
rm -rf /Library/Application\ Support/FLEXnet\ Publisher/Service/11.13.1
rm -rf /Library/Application\ Support/FLEXnet\ Publisher/Service/11.14.1
rm -rf /Library/Application\ Support/FLEXnet\ Publisher/Service/11.16.2
rm -rf /Library/Application\ Support/FLEXnet\ Publisher/Service/11.17.0
rm -rf /Library/Application\ Support/FLEXnet\ Publisher/Service/11.18.3
rm -rf /Library/Fonts/Artifakt*
rm -rf /Library/Frameworks/Adlm.framework
rm -rf /Library/Management/lab_sync/Library/Application\ Support/Autodesk
rm -rf /Library/Preferences/.com.flexnetlicensing
rm -rf /Library/Preferences/FLEXnet\ Publisher/.acadplaceholder
rm -rf /Library/Preferences/com.autodesk*
rm -rf /Users/Shared/Autodesk
rm -rf /Users/admin/Library/Application\ Support/Autodesk
rm -rf /private/var/db/receipts/autodesk*
rm -rf /private/var/db/receipts/com.allegorithmic*
rm -rf /private/var/db/receipts/com.autodesk*
rm -rf /private/var/db/receipts/com.solidangle*
rm -rf /private/var/flexlm
rm -rf /opt/Autodesk
rm -rf /private/tmp/.aksub
rm -rf /private/tmp/AdAppMgrRollBackBackup
rm -rf /private/tmp/AdODIS*
rm -rf /private/tmp/AdskLicensing*
rm -rf /private/tmp/FLEXnet
rm -rf /private/tmp/Maya*
rm -rf /private/tmp/Mudbox*
rm -rf /private/tmp/MudBox*
rm -rf /private/tmp/Install*
rm -rf /private/tmp/LookdevX*
rm -rf /private/tmp/adsk*
rm -rf /private/tmp/autodesk*
rm -rf /private/tmp/bifrost*
rm -rf /private/tmp/bitfrost*
rm -rf /private/tmp/download_dest
rm -rf /private/tmp/installbuilder*
rm -rf /private/tmp/tmp_adsk*
rm -rf /private/tmp/odis*
rm -rf /Library/Application\ Support/Autodesk/AdskLicensing
pkgutil --forget com.autodesk.AdskLicensing > /dev/null 2>&1
pkgutil --forget com.autodesk.* > /dev/null 2>&1
pkgutil --pkgs | grep -i autodesk | xargs -n1 pkgutil --forget > /dev/null 2>&1
echo "Autodesk has been removed"
kwoodard
  • July 18, 2025
#!/bin/zsh
### This script:
### - requires Jamf
### Variables
### Global
odisVolume="Darwin"
### Maya
### Mudbox
### AutoCAD
### Begin script
sleep 5
sleep 5
### Install Maya
sleep 5
### Install Mudbox
sleep 5
### Install AutoCAD
sleep 5
exit 1
echo ""
echo ""
### Remove Autodesk
### Remove
Glad you liked my script! I put so much logging in it because Darwin gave me fits and failed without reason so often. This helped me figure out what was wrong.
Your removal script looks more complete than mine. I’ll compare the two tomorrow when I’m on campus.
