Passing parameters for script using terminal
  • Sep 10, 2024 11:37 PM UTC
  • 243 views
Is it possible to pass parameters for a script through the jamf policy -trigger command? For example, if I wanted to pass an end user's  email into a script that is being run in the policy I am calling can you enter sudo jamf policy -trigger <policyname> <user@email.com>?
iangmyers
  • Employee
  • Sep 11, 2024 1:41 PM UTC
If you are populating the user and location fields in a computers records than you could deploy a PLIST that contains all that info which you can leverage in your scripts.
https://derflounder.wordpress.com/2023/02/25/providing-jamf-pro-computer-inventory-information-via-macos-configuration-profile/
AJPinto
  • Sep 11, 2024 8:50 PM UTC
Technically yes, but functionally no. What problem are you trying to solve by doing this? Maybe with a better idea of the end goal we can provide other options or solutions.
