Pending Management Commands for months
  • July 21, 2023
  • 5 replies
  • 678 views
janzaldua
Hello. I know there are many threads about this already, but I still haven't found out a long term solution for this problem. I also know there is a workaround, which is to re-enroll the device, and yes this works. But this requires scheduling time with the user for 10-15 minutes, and that can add up quickly.
Does anyone know the root cause or how to fix this issue? Here's some info for those that need it.
- We have created an extension attribute that shows if the MDM is communicating or broken
- We have renewed our push certificates
- We have tried the Jamf binary self-heal with the Jamf API, but no luck
It seems the only way to fix this issue is to remove the profile and framework, then re-enroll. This can get even more time consuming when the Profiles do not get removed and you have to wipe the entire system or disable SIP to remove the non-removable profiles.
pete_c
  • July 21, 2023
Cancel all Failed or Crashed commands, then cancel all Pending commands, then send a Blank Push.  The commands to be issued will be recomputed and eventually the device will receive MDM commands successfully.
Remember, MDM stands for 'Maybe Device Management.'
janzaldua
  • July 21, 2023
This helped quite a bit actually. The solution seems to be a mix of your steps and the self heal. I'll have to test on 10+ more devices to ensure this fix actually works, but here is my solution that has worked on a few machines already.
1. Cancel all Pending/Failed commands on that device within Management > Management Commands
2. Run the Self-Heal using the Jamf API (this redeploys the Jamf Management Framework)
After that, a pending command called "InstallApplication" will pop-up. As long as the device is online, it will resolve itself within 5-10 minutes.
Bol
  • July 22, 2023
I use this script on check each day, works well.
https://github.com/rtrouton/rtrouton_scripts/tree/main/rtrouton_scripts/Casper_Scripts/clear_failed_Jamf_Pro_mdm_commands
Hi janzaldua,
We are having the same issues, do you mind sharing the extension attribute you used to track if the MDM is communicating or broken?
janzaldua
  • October 23, 2023
Hi janzaldua,
Hi, no problem:
#!/bin/bash result=$(log show --style compact --predicate '(process CONTAINS "mdmclient")' --last 1d | grep "Unable to create MDM identity") if [[ $result == '' ]] then echo "<result>MDM is communicating</result>" else echo "<result>MDM is broken</result>" fi
