Hi all,
This isn't really JSS related but I'm wondering if anybody knows where to get info about the updates I have pending in my update server for OSX. I have found nothing to read about any of them. A lot are self explanatory but some I would like some more information on before testing them out.
I like starting with this page:
http://support.apple.com/downloads/
but it doesn't include many apps and updates that have been moved over to the App Store.
So I actually found the answer to my own question. If you want to know what a particular update is about, the place to look is in the server.app. Under software updates in the bottom of the screen there is a gear. Highlight an update you're curious about, click the gear, choose to view update. You will get a description. Well... You will sometimes get a description. A lot of them are blank.
