But the policy will work if I run it from self service or if I issue the sudo jamf policy command at terminal. All my policy is running one command "kdestroy -a". Regardless of where it runs from it does not report any errors but when the command is executed during reoccurring checkin the kerberos tickets are not deleted. Its so odd because as I said before when I run it from self service it works and when I issue the sudo jamf policy command it works. So I'm a bit stumped.
Policy does not work at recurring check in
