Policy not running on all users in a device
  • Jan 30, 2025 7:25 PM UTC
  • 95 views
I have a policy to manage the applications that show on the Dock. In the picture provided it shows the triggers and execution frequency. For some reason the policy executed on the local admin account, but since these laptops are in a 1 too many program we have several local Standard accounts created for students. I am noticing that the policy has trouble executing on the other Standard accounts. In the logs of the policy, the device does not even show up, but i know it has executed on the admin account. Any advice or tips? Picture provided shows the triggers and frequency.
Thanks
sdagley
  • Jan 30, 2025 9:32 PM UTC
Probably best not to trigger on Startup, and if you're going to modify 28 Dock items taking a look at https://github.com/kcrawford/dockutil would definitely be recommended.
  • Jan 31, 2025 8:29 AM UTC
Same tips from me, do not use the Startup Event.
Check if the policy runs after login when you run the
sudo jamf policy -event login
in Terminal.
karthikeyan_mac
Forum|alt.badge.img+20
Hi @acamare10
I would also recommend Dockutil for managing Dock.
Thanks
