Updated to Jamf Pro 11.21 yesterday afternoon and have found that when enrolling iPads with a name set in Prestage and the “Enforce Mobile Device Names” option checked, the device record will have the checkbox unchecked when I click Edit on the general tab.  I see 11.21.1 is out this morning, perhaps need to update again and see if this was silently resolved?
PI141235 - "Settings - Device Name" Not Working with Jamf Pro 11.20. When a previously enrolled mobile device is moved to a new PreStage with the "Enforce Mobile Device Names" option enabled and is re-enrolled (without deleting the device record in Jamf Pro), the device name is not updated to the new PreStage naming convention (even though the "Settings - Device Name" command is completed).
I believe you’re hitting some attribute of this PI.
Hmmm that sounds like it might be the issue.  These are devices that have the record deleted already so not exactly the case of the PI but probably related then.  Guess we’ll be manually checking now and watching for an update on that PI.
