PreStage Not Automatically Imaging
  • January 16, 2013
  • 6 views
I've deployed a PreStage today and have found that it logs in to Casper Imaging and pre-populates all the data. However, it doesn't automatically start imaging the device, I have to manually press the Install button. I've successfully used PreStage twice in the past and as far as I can tell the Install configs for those PreStages are exactly the same as this new one.
Any ideas?
1 reply
  • January 16, 2013
Hi. There are 2 options in your Pre-Stage I would check.
Under the General tab, make sure the "Run Automatically During Initial Imaging" box is checked.
Under the Install tab, check the "Automatically Image this Computer the next time Casper Imaging is launched" box.
Its been a long time since I've use Pre-Stage, so I don't remember which of those options does what you're looking for, but I believe its one of them. I'm thinking the one under the Install tab only applies to Auto-Run though.
