Hello all,
It looks like Private Browsing is no longer blocked by the Content Filtering Configuration Profile for iPads after the newest iOS update. Has anyone else run into this issue or does anyone know a work around to block Private Browsing on iPads through a different configuration?
Have seen the same, without immediate solution. Apple does have a DDM setting for turning off private browsing as per https://support.apple.com/guide/deployment/depff7fad9d8/1/web/1.0
I guess making a custom profile for it could be the way forward until Jamf incorporates the setting in its profiles
For those searching for an answer on this topic it looks like it will be an available Blueprint once the devices are on iPadOS26.  Will look forward to testing this out once we start updating.
