Problem deploying a package with installer
  • February 14, 2022
  • 4 replies
  • 193 views
Hello, I'm trying to deploy a package with the installer command and i"m getting some errors. I've tried doing cd /tmp as the other issue suggested but that still wouldn't work.
Currently I have a policy that caches the package on the endpoint at a location I assume was /Library/Application Support/JAMF/Downloads
Then a script that copies that to /tmp and tries to run installer on it. Here is the output:
Script result: cp: /Library/Application Support/JAMF/Downloads/filename.pkg: No such file or directory Feb 14 12:10:13 installer[4032] <Critical>: PFPkg: No file found at path: /private/tmp/filename.pkg Feb 14 12:10:13 installer[4032] <Critical>: PFPackage::packageWithURL - can't instantiate package: /private/tmp/filenamepkg installer: Error - the package path specified was invalid: 'filename.pkg'.
Firstly, from the output I assume the cache location is wrong, but also why is it looking at /private/tmp instead of /tmp?
Here is the script as well:
#!/bin/bash # Find the pkg on your machine and cd to it. filename=$4 cd /tmp cp "/Library/Application Support/JAMF/Downloads/$filename" "/private/tmp" # Create the config for it. echo $filename > filename.txt installer -verbose -pkg $filename -target '/' -dumplog
Any ideas what could be going wrong?
Best answer by mm2270
As @mickl089 mentions, if you're talking about a standard Apple pkg format, these deploy natively in Jamf Pro without needing to cache and then run a script, but perhaps there's some reason that so clear on why you're attempting to do it this way.
BTW, packages cached with Jamf Pro go into /Library/Application\\ Support/JAMF/Waiting\\ Room/
Also, /private/tmp and /tmp are the same location. It's just that using /tmp/ in a script will resolve properly to /private/tmp/ which is it's actual path.
mickl089
  • February 14, 2022
Is this a PKG you want to deploy? If so, you don't need a script at all, or why do you want to solve it this way?
  • February 14, 2022
  • February 14, 2022
I have to deploy it with a script because the package requires some extra config files that i excluded from this post
  • February 14, 2022
Seems like that worked. I change the cp command to point to waiting room instead and it has successfully ran the script! Thank you
