Problem installing pkg using a policy
  • September 7, 2010
  • 5 replies
  • 7 views
Hi all. We have casper suite v7.3.1 and I'm running into an issue when trying to install a simple selfervice.pkg created to update selfservice to the latest version.
The pkg is simply moving the old package to /tmp via a pre-install script then installing the new app to /Applications. Seems simple enough and works when installed locally through installer.app. However when I set it to install via a policy, it fails with the attached error. Any ideas?
![external image link](attachments/692b82b0acf4493e8864fd5c3d943d11)
Forum|alt.badge.img+15
  • 208 replies
  • September 7, 2010
Mare sure you recon the workstation again.
On Sep 7, 2010, at 11:52 AM, Aaron wrote:
we received that same error about the MBS Plugins, recon fixed it.
Thanks
Dan De Rusha
  • 0 replies
  • September 7, 2010
Strange. I thought recon was a one-time thing. I'll try it and see what happens.
  • 0 replies
  • September 7, 2010
I recently had a similar issue and it turned out that I forgot that BOTH the policy AND the trigger need to be scoped to the machine(s) in question.
The policy would run when I ran it by hand, but it seemed like it was never happening when it was supposed to. If you're using a custom trigger for the policy, definitely check its scope.
--Baker
Baker Franke
Computer Science Dept.
University of Chicago Laboratory Schools
773.702.5419
  • 0 replies
  • September 7, 2010
I have it running every 15 while I try some changes. It's scoped to the one test machine, ongoing, with the every 15 trigger. The Self Service app version is updated, the app modification time is correct, etc. The jamf.log shows an install. This isn't anything different than I usually do with a number of different apps.
Tue Sep 7 11:18:18 2820-mp jamf[80789]: Checking for policies triggered by "every15"...
Tue Sep 7 11:18:20 2820-mp jamf[80789]: Executing Policy Install Self Service_7.3.0...
Tue Sep 7 11:18:21 2820-mp jamf[80789]: Installing selfservice7.3.pkg...
Tue Sep 7 11:18:34 2820-mp jamf[80789]: Successfully installed selfservice7.3.pkg.
  • 0 replies
  • September 8, 2010
Hi Terry,
Yup, that was it. I was using a preflight script to move it that had a typo. Once I fixed that, it now works. The strange thing was that it would install over the old one when I ran the package locally, but only caused an issue when installing via a policy.
Anyway, removing the previous version works. Thanks for the suggestion.
- Aaron
Cookie policy
Cookie settings
