Are you seeing any error messages?
Do they install normally ok?
Regards,
Ben.
            Both of the installations fail. According to the install.log they usually
fail inside a sub package script. The one that is driving the most crazy
at the moment is CheckPoint FDE. The installer for FDE has an "isp" file
that has to coexist in the same directory as the installer to do a silent
install with the correct settings. The installer native installer from the
vendor is a mpkg. I placed the mpkg and the isp filed into
/tmp/fde_install and captured them with Composer, then created a post
flight script to install the fde mpkg package. This works great in 10.5
and 10.6. 10.7 blows up running a script in one of the sub packages inside
the main installer that references the isp file that is in the same tmp
directory. I am wondering if Lion is running the installer in a "sandbox"
type mode so it can't fully read the isp file. Funny thing, is this only
fails if I run the package through casper. Policy, Self Service or Remote
all fail. If I run the installer from the desktop, it runs like a champ.
Paul Austin
End User Computing, Platform Engineering
Wells Fargo | 1525 West W.T. Harris Blvd  | Charlotte, NC 28262
MAC D1112-036
Tel 704 427-0903
paul.austin at wellsfargo.com
            Try putting the stuff you would have dumped in /private/tmp inside the
On 7 December 2011 05:10,  <Paul.Austin at wellsfargo.com> wrote:
package's Resources, then do what needs to be done in the post scripts
using the $1 variable. For example:
postflight:
installer -target / -verbose -pkg $1/Contents/Resources/XCode.mpkg
            A good example of this kind of workflow is the Parallels deployment wrapper. When deploying virtual machines, the wrapper's postflight script will mv them into /Users/Shared/Parallels directory.
Doug Brown wrote:
For most deployments we've been installing into the /tmp directory but it's definitely time to review the workflow and adapt the above.
Don
