problem with installpkgfromdmg
  • May 4, 2018
  • 8 replies
  • 53 views
hi i am trying to install office 2016 using this method the o/s is 10.13 jamf is version 10 also
i firstly cache the pkg and that works the script then runs but errors, i downloaded the script from here i think its to do with the location for the jamf binaries in the script i may be wrong,
could it be because its high sierra and something changed in the file structure i dont want to start just changing the script unless thats whats needed, the info says do not alter bellow this section
any advice is most welcome i have been working with jamf for around 3 weeks preparing the different packages etc
it works if i use remote to install the cache or a maintenance script but i will get more control this way
  • May 7, 2018
For Office we just use the PKG installer from MS. We use "installPKGfromDMG.sh" with Adobe products only. You must be sure you put your DMG name in the Parameter 4, for example: "Microsoft_Office_2016_16.12.18041000_Installer.DMG". DO NOT USE "" in your Parameters.
  • May 15, 2018
great thanks, I ve now tried the derflounder method and it works very well i just need to package the plists which is pretty straight forward.
thanks
  • August 1, 2018
We've experienced issues with JAMFPro 10.4.0 with the installPKGfromDMG script too...
Now the JSS appears to a respect exit codes (Yay!)... Downside is the existing installPKGfromDMG script appears not to return/pass an exit code if a PKG fails to install (Boo!).
Additionally we've experienced after a previous failed attempt, the script fails because of an existing DMG mount or existing shadow file..
After a bit of editing, we've come up with something good...
It addresses..
Supplying parameter 5 with "YES" without quotes and case sensitive allows PKG exit code to be bypassed and returns a forced exit code of 0 to the JSS (if needed).
If a previous DMG mount is detected, will attempt unmount
If a previous shadow file is detected, will delete it before attempting mounting DMG
Passes and outputs PKG exit code to log
* Passes and outputs exit codes to JSS
eg screenshots
Successful
Failed
Our script is below
# Copyright (c) 2011, JAMF Software, LLC.  All rights reserved.
#       Redistribution and use in source and binary forms, with or without
#       modification, are permitted provided that the following conditions are met:
#               * Redistributions of source code must retain the above copyright
#                 notice, this list of conditions and the following disclaimer.
#               * Redistributions in binary form must reproduce the above copyright
#                 notice, this list of conditions and the following disclaimer in the
#                 documentation and/or other materials provided with the distribution.
#               * Neither the name of the JAMF Software, LLC nor the
#                 names of its contributors may be used to endorse or promote products
#                 derived from this software without specific prior written permission.
#       THIS SOFTWARE IS PROVIDED BY JAMF SOFTWARE, LLC "AS IS" AND ANY
#       EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
#       WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
#       DISCLAIMED. IN NO EVENT SHALL JAMF SOFTWARE, LLC BE LIABLE FOR ANY
#       DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
#       (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
#       LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
#       ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
#       (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
#       SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# SUPPORT FOR THIS PROGRAM
#       This program is distributed "as is" by JAMF Software, LLC's Resource Kit team. For more
#       information or support for the Resource Kit, please utilize the following resources:
#               http://list.jamfsoftware.com/mailman/listinfo/resourcekit
#               http://www.jamfsoftware.com/support/resource-kit
#       Please reference our SLA for information regarding support of this application:
#               http://www.jamfsoftware.com/support/resource-kit-sla
# ABOUT THIS PROGRAM
# NAME
#   installPKGfromDMG.sh -- Install a PKG wrapped inside a DMG
# SYNOPSIS
#   sudo installPKGfromDMG.sh
# DESCRIPTION
#   This script will mount a DMG and install a PKG file wrapped inside.  The script assumes that
#   the DMG has been previously cached to the machine to:
#       /Library/Application Support/JAMF/Waiting Room/
#   This is the default location that a package will be cached to when selecting the "Cache"
#   option within a policy or Casper Remote.
#   To use this script, please follow the following workflow:
#   Step 1: Wrap a PKG inside a DMG
#       1.  Open Disk Utility.
#       2.  Navigate to File > New > Disk Image from Folder.
#       3.  Select the PKG and click the Image button.
#       4.  Name the package after the original PKG.
#       5.  Choose a location for the package and then click Save.
#   Step 2: Upload the DMG and installPKGfromDMG.sh script to Casper Admin:
#       1.  Open Casper Admin and authenticate.
#       2.  Drag the DMG you created in the previous procedure to the Package pane in Casper Admin.
#       3.  Drag the installPKGfromDMG.sh script to the Package pane in Casper Admin.
#       4.  Save your changes and quit the application.
#   Step 3: Create a policy to install the DMG:
#       1.  Log in to the JSS with a web browser.
#       2.  Click the Management tab.
#       3.  Click the Policies link.
#       4.  Click the Create Policy button.
#       5.  Select the Create policy manually option and click Continue.
#       6.  Configure the options on the General and Scope panes as needed.
#       7.  Click the Packages button, and then click the Add Package link.
#       8.  Across from DMG, choose “Cache” from the Action pop-up menu and then click the
#           "Add Packages" button.
#       9.  Click the Scripts button, and then click the Add Script link.
#       10. Across from the installPKGfromDMG.sh script, choose “Run After” from the Action pop-up menu.
#       11. Enter the name of the original DMG in the Parameter 4 field.
#       12. Click Save.
# HISTORY
#   Version: 1.0
#   - Created by Nick Amundsen on July 22, 2011
#   - Modified by Blake Suggett on July 24, 2018
# DEFINE VARIABLES & READ IN PARAMETERS
# HARDCODED VALUES SET HERE
# Variables set by Casper - To manually override, remove the comment for the given variable
# targetDrive=""  # Casper will pass this parameter as "Target Drive" if left commented out
# computerName=""  # Casper will pass this parameter as "Computer Name" if left commented out
# userName=""  # Casper will pass this parameter as "User Name" if left commented out. Usernames
#                  can only be passed if the script is triggered at login, logout, or by Self Service
# Variables used for logging
logFile="/private/var/log/jamf.log"
# Variables used by this script.
dmgName=""
forcesuccessflag=""
# CHECK TO SEE IF A VALUE WERE PASSED IN FOR PARAMETERS AND ASSIGN THEM
if [ "$1" != "" ] && [ "$targetDrive" == "" ]; then
    targetDrive="$1"
if [ "$2" != "" ] && [ "$computerName" == "" ]; then
    computerName="$2"
if [ "$3" != "" ] && [ "$userName" == "" ]; then
    userName="$3"
if [ "$4" != "" ] && [ "$dmgName" == "" ]; then
    dmgName="$4"
if [ "$5" != "" ] && [ "$forcesuccessflag" == "" ]; then
    forcesuccessflag="$5"
# LOGGING FUNCTION
log () {
    echo $1
    echo $(date "+%a %b %d %H:%M:%S $HOSTNAME ScriptOutput: ") $1 >> $logFile
# VARIABLE VERIFICATION FUNCTION
log "installPKGfromDMG.sh"
verifyVariable () {
eval variableValue=$$1
if [ "$variableValue" != "" ]; then
    log "Variable "$1" value is set to: $variableValue"
    log "Variable "$1" is blank.  Please assign a value to the variable."
    exit 1
# SCRIPT CONTENTS - DO NOT MODIFY BELOW THIS LINE
# Verify Variables
verifyVariable dmgName
if [ "$forcesuccessflag" = "YES" ]; then
    log "Variable "forcesuccessflag" to JSS explicitly declared...: $forcesuccessflag"
elif [ "$forcesuccessflag" != "YES" ]; then
    log "Variable "forcesuccessflag" to JSS not explicitly declared, defaulting to NO..."
# Attempt to remove any existing mounts
UnmountDMGNameOnly=`echo $dmgName | sed 's/.dmg*//'`
if [[ -d /Volumes/$UnmountDMGNameOnly ]] ; then
    log "Found an existing mounted DMG, unmounting..."
    hdiutil detach /Volumes/$UnmountDMGNameOnly -force
if [[ -f /Library/Application Support/JAMF/Waiting Room/$dmgName.shadow ]] ; then
    log "Found an existing shadow file, removing..."
    rm -f /Library/Application Support/JAMF/Waiting Room/$dmgName.shadow
# Mount the DMG
log "Mounting the DMG $dmgName..."
# mountResult
mountResult=`/usr/bin/hdiutil mount -private -noautoopen -noverify /Library/Application Support/JAMF/Waiting Room/$dmgName -shadow`
mountResultExitCode=($?)
# mountVolume
mountVolume=`echo "$mountResult" | grep Volumes | awk '{print $3}'`
mountVolumeExitCode=($?)
# mountDevice
mountDevice=`echo "$mountResult" | grep disk | head -1 | awk '{print $1}'`
mountDeviceExitCode=($?)
# Check DMG mount parameters are ok
if [[ $mountResultExitCode == 0 ]] && [[ $mountVolumeExitCode == 0 ]] && [[ $mountDeviceExitCode == 0 ]] ; then
    log "DMG mounted successfully as volume $mountVolume on device $mountDevice."
elif [[ $mountResultExitCode != 0 ]] ; then
    log "$mountResult"
    log "There was an error mounting the DMG. mountResult hdiutil exit code: $mountResultExitCode"
    exit 1
elif [[ $mountVolumeExitCode != 0 ]] ; then
    log "$mountVolume"
    log "There was an error mounting the DMG. mountVolume grep volume exit code: $mountVolumeExitCode"
    exit 1
elif [[ $mountDeviceExitCode != 0 ]] ; then
    log "$mountDevice"
    log "There was an error mounting the DMG. mountDevice grep disk exit code: $mountDeviceExitCode"
    exit 1
# Find the PKG in the DMG
packageName=`ls $mountVolume | grep "pkg"`
# Install the PKG wrapped inside the DMG
log "Installing Package $packageName from mount path $mountVolume..."
/usr/local/jamf/bin/jamf install -path $mountVolume -package $packageName
PKGExitCode=($?)
if [[ "$5" == "YES" ]]; then
    log "PKG exit code was: $PKGExitCode"
    log "Exit code 0 was passed to JSS"
    log "Successfully installed"
    # Unmount the DMG
    echo "Unmounting disk $mountDevice..."
    hdiutil detach "$mountDevice" -force
    UnmountDMGExitCode=($?)
    # If unmount failed attempt unmount using the volumes directory path
    if [ $UnmountDMGExitCode != 0 ] ; then
        log "Unable to unmount using native mountDevice... Attempting volumes unmount..."
    if [ $UnmountDMGExitCode == 0 ] ; then
        log "Successfully unmounted"
    # Delete the DMG
    /bin/rm /Library/Application Support/JAMF/Waiting Room/$dmgName
elif [[ "$PKGExitCode" == 0 ]]; then
    log "Exit code $PKGExitCode was passed to JSS"
    # Unmount the DMG
    # Delete the DMG
    log "PKG exit code was...: $PKGExitCode"
    log "Failed installation"
    # Unmount the DMG
    # Delete the DMG
    exit 1
Hope this helps someone....
  • January 24, 2019
  • March 3, 2020
Another improvement
installPKGsfromDMG
  • August 3, 2020
Anyone else seeing errors when installing the pkg?
The installer reported: installer: Error - the package path specified was invalid: '/Library/Application Support/JAMF/Downloads/mypackage.pkg'.
It caches and mounts the dmg as expected, finds the pkg in the mount path, calls out to install the package with the proper name and begins to install then fails. The policy worked on 7/29/20 then mysteriously stopped working this morning 8/3/20. I had been using version 1 of this script and saw several improvements had been made so I updated the script but the issue remained the same.
EDIT - Seems to have been a damaged DMG. Deleting and reuploading the DMG, resyncing DPs and replacing the PKG in the policies resolved it.
  • August 6, 2021
Another improvement
installPKGsfromDMG
@bsuggett Link is broken. Where can we find the latest update?
  • August 7, 2021
