Problem with JIM does not work
  • November 16, 2018
  • 91 views
Problem with JIM does not work with Web App.
It turns out that it does not work since I installed a signed public certificate from my Web App (Jamf Pro) I publish everything from an environment in Amazon Web Services.
Have some idea of how I can solve it, the configuration of JIM if it is successfully achieved.
The Apache server and the JIM server if they repsonden between them.
2018-11-15 17:06:00,445 WARN jsam-core [[iPOJO] pool-1-thread-1] [WARNING] com.jamfsoftware.jsam.core.jss.JssCheckinManager : No service interface found in the class hierarchy, use the implementation class
2018-11-15 17:06:00,711 INFO c.j.j.c.u.PaxLoggingStartupListener [[iPOJO] pool-1-thread-1] Waiting for OSGI Log Service
2018-11-15 17:06:01,727 INFO c.j.j.c.u.PaxLoggingStartupListener [[iPOJO] pool-1-thread-1] OSGI Log Service is initialized
2018-11-15 17:06:01,727 INFO c.j.j.c.j.JssCommunicationServiceImpl [[iPOJO] pool-1-thread-1] Beginning enrollment process
2018-11-15 17:06:02,664 WARN c.j.j.c.k.p.AclFileSystemFacade [[iPOJO] pool-1-thread-1] There should be exactly 1 ACL entry allowing access to .configjsam.jsam_encrypted_keys.properties. There are 3. [BUILTINAdministrators:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW, NT AUTHORITYLOCAL SERVICE:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW, NT AUTHORITYSYSTEM:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW]
2018-11-15 17:06:02,680 INFO c.j.j.c.k.p.JsamPermissionEnforcer [[iPOJO] pool-1-thread-1] Enforcing permissions for .configjsam.jsam_encrypted_keys.properties. Only process owner should be allowed to read and write this file.
2018-11-15 17:06:03,164 WARN c.j.j.c.k.p.AclFileSystemFacade [[iPOJO] pool-1-thread-1] There should be exactly 1 ACL entry allowing access to .configjsamkeystore.jks. There are 3. [BUILTINAdministrators:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW, NT AUTHORITYLOCAL SERVICE:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW, NT AUTHORITYSYSTEM:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW]
2018-11-15 17:06:03,164 INFO c.j.j.c.k.p.JsamPermissionEnforcer [[iPOJO] pool-1-thread-1] Enforcing permissions for .configjsamkeystore.jks. Only process owner should be allowed to read and write this file.
2018-11-15 17:06:03,977 ERROR jsam-core [[iPOJO] pool-1-thread-1] [ERROR] : Cannot invoke the post-registration callback initialize
java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.felix.ipojo.util.Callback.call(Callback.java:233) at org.apache.felix.ipojo.handlers.providedservice.ProvidedService.registerService(ProvidedService.java:390) at org.apache.felix.ipojo.handlers.providedservice.ProvidedServiceHandler.__M_stateChanged(ProvidedServiceHandler.java:503) at org.apache.felix.ipojo.handlers.providedservice.ProvidedServiceHandler.stateChanged(ProvidedServiceHandler.java) at org.apache.felix.ipojo.InstanceManager.setState(InstanceManager.java:560) at org.apache.felix.ipojo.InstanceManager.stateChanged(InstanceManager.java:1533) at org.apache.felix.ipojo.InstanceManager.setState(InstanceManager.java:585) at org.apache.felix.ipojo.HandlerManager.stateChanged(HandlerManager.java:239) at org.apache.felix.ipojo.Handler.setValidity(Handler.java:174) at org.apache.felix.ipojo.handlers.dependency.DependencyHandler.__M_checkContext(DependencyHandler.java:170) at org.apache.felix.ipojo.handlers.dependency.DependencyHandler.checkContext(DependencyHandler.java) at org.apache.felix.ipojo.handlers.dependency.DependencyHandler.__M_validate(DependencyHandler.java:133) at org.apache.felix.ipojo.handlers.dependency.DependencyHandler.validate(DependencyHandler.java) at org.apache.felix.ipojo.util.DependencyModel.validate(DependencyModel.java:522) at org.apache.felix.ipojo.util.DependencyModel.computeAndSetDependencyState(DependencyModel.java:362) at org.apache.felix.ipojo.util.DependencyModel.onChange(DependencyModel.java:1123) at org.apache.felix.ipojo.dependency.impl.ServiceReferenceManager.fireUpdate(ServiceReferenceManager.java:561) at org.apache.felix.ipojo.dependency.impl.ServiceReferenceManager.onNewMatchingService(ServiceReferenceManager.java:525) at org.apache.felix.ipojo.dependency.impl.ServiceReferenceManager.addedService(ServiceReferenceManager.java:504) at org.apache.felix.ipojo.util.Tracker$Tracked.trackAdding(Tracker.java:711) at org.apache.felix.ipojo.util.Tracker$Tracked.track(Tracker.java:672) at org.apache.felix.ipojo.util.Tracker$Tracked.serviceChanged(Tracker.java:633) at org.apache.felix.framework.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:990) at org.apache.felix.framework.EventDispatcher.fireEventImmediately(EventDispatcher.java:838) at org.apache.felix.framework.EventDispatcher.fireServiceEvent(EventDispatcher.java:545) at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:4557) at org.apache.felix.framework.Felix.registerService(Felix.java:3549) at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:348) at org.apache.felix.ipojo.IPojoContext.registerService(IPojoContext.java:395) at org.apache.felix.ipojo.handlers.providedservice.ProvidedService.registerService(ProvidedService.java:351) at org.apache.felix.ipojo.handlers.providedservice.ProvidedServiceHandler.__M_stateChanged(ProvidedServiceHandler.java:503) at org.apache.felix.ipojo.handlers.providedservice.ProvidedServiceHandler.stateChanged(ProvidedServiceHandler.java) at org.apache.felix.ipojo.InstanceManager.setState(InstanceManager.java:560) at org.apache.felix.ipojo.InstanceManager.start(InstanceManager.java:440) at org.apache.felix.ipojo.ComponentFactory.createInstance(ComponentFactory.java:179) at org.apache.felix.ipojo.IPojoFactory.createComponentInstance(IPojoFactory.java:319) at org.apache.felix.ipojo.IPojoFactory.createComponentInstance(IPojoFactory.java:240) at org.apache.felix.ipojo.extender.internal.linker.ManagedType$InstanceSupport$1.call(ManagedType.java:312) at org.apache.felix.ipojo.extender.internal.linker.ManagedType$InstanceSupport$1.call(ManagedType.java:306) at org.apache.felix.ipojo.extender.internal.queue.JobInfoCallable.call(JobInfoCallable.java:114) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748)
Caused by: com.jamfsoftware.jsam.core.JsamException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at com.jamfsoftware.jsam.core.jss.JssCommunicationInternalClientImpl.__M_getResponse(JssCommunicationInternalClientImpl.java:123) at com.jamfsoftware.jsam.core.jss.JssCommunicationInternalClientImpl.getResponse(JssCommunicationInternalClientImpl.java) at com.jamfsoftware.jsam.core.jss.JssCommunicationInternalClient$$Proxy.getResponse(Unknown Source) at com.jamfsoftware.jsam.core.jss.JssCommunicationServiceImpl.__M_getResponse(JssCommunicationServiceImpl.java:147) at com.jamfsoftware.jsam.core.jss.JssCommunicationServiceImpl.getResponse(JssCommunicationServiceImpl.java) at com.jamfsoftware.jsam.core.jss.JssCommunicationServiceImpl.__M_enroll(JssCommunicationServiceImpl.java:126) at com.jamfsoftware.jsam.core.jss.JssCommunicationServiceImpl.enroll(JssCommunicationServiceImpl.java) at com.jamfsoftware.jsam.core.jss.JssCommunicationService$$Proxy.enroll(Unknown Source) at com.jamfsoftware.jsam.core.service.impl.JsamCoreActivationServiceImpl.__M_initialize(JsamCoreActivationServiceImpl.java:64) at com.jamfsoftware.jsam.core.service.impl.JsamCoreActivationServiceImpl.initialize(JsamCoreActivationServiceImpl.java) ... 48 more
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1964) at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:328) at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:322) at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1614) at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:216) at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1052) at sun.security.ssl.Handshaker.process_record(Handshaker.java:987) at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1072) at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:394) at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:353) at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:134) at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:353) at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:380) at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236) at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184) at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88) at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110) at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184) at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82) at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:107) at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:55) at com.jamfsoftware.jsam.core.jss.JssCommunicationInternalClientImpl.__M_getResponse(JssCommunicationInternalClientImpl.java:113) ... 57 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397) at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302) at sun.security.validator.Validator.validate(Validator.java:262) at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324) at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229) at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:105) at com.jamfsoftware.jsam.core.keystore.AugmentedTrustManager.checkServerTrusted(AugmentedTrustManager.java:81) at sun.security.ssl.AbstractTrustManagerWrapper.checkServerTrusted(SSLContextImpl.java:992) at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1596) ... 78 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280) at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392) ... 86 more
Best answer by XMY7250
Hello excellent day was my certificate did not have the intermediary nor the root.
The administrator of certificates of my company returned it to me to send correctly in chain.
Forum|alt.badge.img+33
This line makes me think you've hit a Java issue:
@bentoms also hit this problem and has a solution for it:
https://macmule.com/2018/10/11/java-8-update-181-ldap-changes-jamf-pro-connectivity/
  • November 16, 2018
Hello rtrouton,
I just downloaded the Java version as indicated by your link, in advance I appreciate your support.
I proceeded to remove from the JIM server, the JIM also removed the folder that generates JIM in the files program, ranite the server and likewise with the Java install again everything with the indicated previous version of Java.
I still have the same problem, this is the new LOG.
¿Will they have any recommendations?
2018-11-16 12:03:49,476 WARN jsam-core [[iPOJO] pool-1-thread-1] [WARNING] com.jamfsoftware.jsam.core.jss.JssCheckinManager : No service interface found in the class hierarchy, use the implementation class
2018-11-16 12:03:49,766 INFO c.j.j.c.u.PaxLoggingStartupListener [[iPOJO] pool-1-thread-1] Waiting for OSGI Log Service
2018-11-16 12:03:50,797 INFO c.j.j.c.u.PaxLoggingStartupListener [[iPOJO] pool-1-thread-1] OSGI Log Service is initialized
2018-11-16 12:03:50,797 INFO c.j.j.c.j.JssCommunicationServiceImpl [[iPOJO] pool-1-thread-1] Beginning enrollment process
2018-11-16 12:03:51,375 WARN c.j.j.c.k.p.AclFileSystemFacade [[iPOJO] pool-1-thread-1] There should be exactly 1 ACL entry allowing access to .configjsam.jsam_encrypted_keys.properties. There are 3. [BUILTINAdministrators:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW, NT AUTHORITYLOCAL SERVICE:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW, NT AUTHORITYSYSTEM:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW]
2018-11-16 12:03:51,375 INFO c.j.j.c.k.p.JsamPermissionEnforcer [[iPOJO] pool-1-thread-1] Enforcing permissions for .configjsam.jsam_encrypted_keys.properties. Only process owner should be allowed to read and write this file.
2018-11-16 12:03:51,688 WARN c.j.j.c.k.p.AclFileSystemFacade [[iPOJO] pool-1-thread-1] There should be exactly 1 ACL entry allowing access to .configjsamkeystore.jks. There are 3. [BUILTINAdministrators:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW, NT AUTHORITYLOCAL SERVICE:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW, NT AUTHORITYSYSTEM:READ_DATA/WRITE_DATA/APPEND_DATA/READ_NAMED_ATTRS/WRITE_NAMED_ATTRS/EXECUTE/DELETE_CHILD/READ_ATTRIBUTES/WRITE_ATTRIBUTES/DELETE/READ_ACL/WRITE_ACL/WRITE_OWNER/SYNCHRONIZE:ALLOW]
2018-11-16 12:03:51,688 INFO c.j.j.c.k.p.JsamPermissionEnforcer [[iPOJO] pool-1-thread-1] Enforcing permissions for .configjsamkeystore.jks. Only process owner should be allowed to read and write this file.
2018-11-16 12:03:52,985 ERROR jsam-core [[iPOJO] pool-1-thread-1] [ERROR] : Cannot invoke the post-registration callback initialize
java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.felix.ipojo.util.Callback.call(Callback.java:233) at org.apache.felix.ipojo.handlers.providedservice.ProvidedService.registerService(ProvidedService.java:390) at org.apache.felix.ipojo.handlers.providedservice.ProvidedServiceHandler.__M_stateChanged(ProvidedServiceHandler.java:503) at org.apache.felix.ipojo.handlers.providedservice.ProvidedServiceHandler.stateChanged(ProvidedServiceHandler.java) at org.apache.felix.ipojo.InstanceManager.setState(InstanceManager.java:560) at org.apache.felix.ipojo.InstanceManager.stateChanged(InstanceManager.java:1533) at org.apache.felix.ipojo.InstanceManager.setState(InstanceManager.java:585) at org.apache.felix.ipojo.HandlerManager.stateChanged(HandlerManager.java:239) at org.apache.felix.ipojo.Handler.setValidity(Handler.java:174) at org.apache.felix.ipojo.handlers.dependency.DependencyHandler.__M_checkContext(DependencyHandler.java:170) at org.apache.felix.ipojo.handlers.dependency.DependencyHandler.checkContext(DependencyHandler.java) at org.apache.felix.ipojo.handlers.dependency.DependencyHandler.__M_validate(DependencyHandler.java:133) at org.apache.felix.ipojo.handlers.dependency.DependencyHandler.validate(DependencyHandler.java) at org.apache.felix.ipojo.util.DependencyModel.validate(DependencyModel.java:522) at org.apache.felix.ipojo.util.DependencyModel.computeAndSetDependencyState(DependencyModel.java:362) at org.apache.felix.ipojo.util.DependencyModel.onChange(DependencyModel.java:1123) at org.apache.felix.ipojo.dependency.impl.ServiceReferenceManager.fireUpdate(ServiceReferenceManager.java:561) at org.apache.felix.ipojo.dependency.impl.ServiceReferenceManager.onNewMatchingService(ServiceReferenceManager.java:525) at org.apache.felix.ipojo.dependency.impl.ServiceReferenceManager.addedService(ServiceReferenceManager.java:504) at org.apache.felix.ipojo.util.Tracker$Tracked.trackAdding(Tracker.java:711) at org.apache.felix.ipojo.util.Tracker$Tracked.track(Tracker.java:672) at org.apache.felix.ipojo.util.Tracker$Tracked.serviceChanged(Tracker.java:633) at org.apache.felix.framework.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:990) at org.apache.felix.framework.EventDispatcher.fireEventImmediately(EventDispatcher.java:838) at org.apache.felix.framework.EventDispatcher.fireServiceEvent(EventDispatcher.java:545) at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:4557) at org.apache.felix.framework.Felix.registerService(Felix.java:3549) at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:348) at org.apache.felix.ipojo.IPojoContext.registerService(IPojoContext.java:395) at org.apache.felix.ipojo.handlers.providedservice.ProvidedService.registerService(ProvidedService.java:351) at org.apache.felix.ipojo.handlers.providedservice.ProvidedServiceHandler.__M_stateChanged(ProvidedServiceHandler.java:503) at org.apache.felix.ipojo.handlers.providedservice.ProvidedServiceHandler.stateChanged(ProvidedServiceHandler.java) at org.apache.felix.ipojo.InstanceManager.setState(InstanceManager.java:560) at org.apache.felix.ipojo.InstanceManager.start(InstanceManager.java:440) at org.apache.felix.ipojo.ComponentFactory.createInstance(ComponentFactory.java:179) at org.apache.felix.ipojo.IPojoFactory.createComponentInstance(IPojoFactory.java:319) at org.apache.felix.ipojo.IPojoFactory.createComponentInstance(IPojoFactory.java:240) at org.apache.felix.ipojo.extender.internal.linker.ManagedType$InstanceSupport$1.call(ManagedType.java:312) at org.apache.felix.ipojo.extender.internal.linker.ManagedType$InstanceSupport$1.call(ManagedType.java:306) at org.apache.felix.ipojo.extender.internal.queue.JobInfoCallable.call(JobInfoCallable.java:114) at java.util.concurrent.FutureTask.run(Unknown Source) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source)
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.ssl.Alerts.getSSLException(Unknown Source) at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source) at sun.security.ssl.Handshaker.fatalSE(Unknown Source) at sun.security.ssl.Handshaker.fatalSE(Unknown Source) at sun.security.ssl.ClientHandshaker.serverCertificate(Unknown Source) at sun.security.ssl.ClientHandshaker.processMessage(Unknown Source) at sun.security.ssl.Handshaker.processLoop(Unknown Source) at sun.security.ssl.Handshaker.process_record(Unknown Source) at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source) at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source) at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:394) at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:353) at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:134) at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:353) at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:380) at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236) at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184) at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88) at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110) at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184) at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82) at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:107) at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:55) at com.jamfsoftware.jsam.core.jss.JssCommunicationInternalClientImpl.__M_getResponse(JssCommunicationInternalClientImpl.java:113) ... 57 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.validator.PKIXValidator.doBuild(Unknown Source) at sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at sun.security.validator.Validator.validate(Unknown Source) at sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) at com.jamfsoftware.jsam.core.keystore.AugmentedTrustManager.checkServerTrusted(AugmentedTrustManager.java:81) at sun.security.ssl.AbstractTrustManagerWrapper.checkServerTrusted(Unknown Source) ... 79 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.security.cert.CertPathBuilder.build(Unknown Source) ... 87 more
  • November 23, 2018
